its user error compounded by ****** made cables and designed so they dont fit correctlyWell, what i am taking from that video is, its probably 99.9% user error in the end, make sure its 100% inserted, your be very unlucky to get a bad connector it seems.
^^ good stuff
I agree, when your get your 4090 adaptor or cables (even if it's Cablemod) - inspect the connector for debris, perhaps blow some air if there is any loose debris to remove it. Then insert the cable straight, do not wiggle it and make sure it's fully in and then follow the normal rules on not bending the cable too sharply. That should prevent any issue other than if the cable has a manufacturing failure that you cannot prevent.
Yeh, sorry your right on that matter also, there needed to be a better click/locking clip as well.
Yep and as I thought the longer this went on it was user error, In all honesty I'm glad GN did this research and video to call out all other so called experts because as a user like myself when you hear techtubers like Igor and Jay just guessing and blaming Nvidia a lot of people would listen when the fact is I've seen some pics of some of these on this Reddit and you can clearly see a gap between the plug base and the connector tip.Some more info here.
We know no user likes to be blamed for the issue or because it happened to them but it wouldn't surprise me in the slightest that the users that it has happened to they have tried to cover up their mistake or oversight by trying not to show that it wasn't connected properly.
It's not a dig at inexperienced users per say and the connector is stiff I know that from first hand experience but come on if you're really not that competent in connecting a cable together then you really shouldn't be going near this sort of equipment.
Look we all make mistakes I have in the past but experience has always taught make sure everything is plugged and seated to the best of your knowledge, There should not be any gap in any connector on the PC, You may get away with a PWM fan header not connected properly because of the low power but you're not going to get away with that at these sort of wattages.
Isn't it 10 per cent of 1 per centWell was in fact 0.1% so 1000% less than 1% even, 0.1 to 1 = 1000%
Well it could be, but 0.1 to 0.2, aint that 100% as its doubleIsn't it 10 per cent of 1 per cent
and so on, as we are talking percentages here.The adapters have two different types of connectors yet only one type of connector is showing melted in a reddit megathread.So the percentages of melting cables was less than 1% and it is likely a 99% user error caused issue.
So much drama.
Don't disagree that things could be better, always space for improvement.The adapters have two different types of connectors yet only one type of connector is showing melted in a reddit megathread.
A design that requires perfection in manufactuaring and implementation to avoid catastrophic failure is a bad design.
To be fair to the design, it seems to require two errors at the same time before it fails so terribly. (I could see this issue not getting caught in testing)
Failing to plug it in all the was doesn’t cause it to melt.
Bending the cable doesn’t cause it to melt.
Laterally loading a connector that *also* isn't fully inserted seems to be the most reliable way to get the connector to melt.
Some users have reported that some of these connectors simply don't want to plug in. Pictures of connectors with plastic *inside* the slot pins have been posted.
The 12VHPWR connector seems to lend itself to not being fully seated in a way that normal PCIe 8-pins don't.
Couple that with the fact that most of these cards can't fit into most cases without the cable hitting the side panel and causing some sort of bend in the cables, and you get a megathread exposing the issue.
The shortened sense pin change seems like an effective way to avoid the worst mode of failure.
its not all the users fault if your connector is built to shoddy standards that dont lock in correctly and can be containated from the factory but you keep doing you and shill for nvidia all you likeUser error…
User error…
Refuse to accept user error as being the error
USER ERROR
Fully insert pins - NO I LIKE IT DANGLING
I want to blame someone for my stupidity - Nvidia it is all your fault.
Honestly, this connector should just be avoided until the format matures a bit tbh. But someone had to make the first jump. Might as well be the big bad Nvidia
User error…
User error…
USER ERROR
