Bought the 19" Hanns-G panel home today. Tucks nicely in corner of my work desk. With DVI and VGA inputs that means both of my current retro builds can be set up on it properly.
Still great picture quality too tbh.
Had a play with the Q6600 and managed to get an overclock upto 2.65ghz using the AI Overclock function in BIOS which was nice.
Also managed to find someone selling new old stock of the akasa Vortexx Neo GPU coolers so pick one up along with a PCI-E 6pin to 3x molex converter cable so I can get power properly to the X1950s 2x molex power connections. Reading up those cards get power starved easily and the artifact like nutters. Being so when I tested it I was using a non brand 500w test PSU I thought I should try it again now the 800w is in there!
Intel really were streets ahead at that period!That's the great thing about LCD panels having two inputs, very useful
I'm actually messing around once again with a Q6700 but running it at 1333MHz FSB for a 3.3GHz clock speed. It's on a G41 board and seems stable with 1.34v input into the BIOS which in CPUz and HWmonitor comes out at 1.3 or so. Currently got a fairly modern 120mm tower hsf on it which is quite and keeps it under 55c.
One benchmark I've been meaning to do for ages is a comparison between the 2007 Q6700 and a 2015 AMD Pro A8 8650B 3.2 - 3.9GHz. The overclocked q6700 actually gets 329points on cinebench r15 whereas the AMD was maxing out at 280 best of 3 runs. Ouch.
Just had a frustrating fight all day trying to get the BIOS updated on the P5NE-SLI. That board is feature rich but makes me want to cry lol
FINALLY there and its up and running on latest bios version, but now it won't boot with both the gtx260s in it. Think it might be the data cable situation....another wonderful nuance of the board.....second card fouls them! So it's not sat quite flat. Time to rip the SLI setup out again and look what can be done lol
Agreed, still my go tothe best NFS game there was!
they just need to stop with all the new shonky ones and remaster it, purely cosmetic rebuildIts not pretty as the new caps are a bit bigger but they are in and workingBeen thinking about rebuilding what I used to call my "main" retro machine for a while which had been mostly sidelined because it was getting unstable and unreliable..
Stripped it down today and think I might have found the cause of that reliability issue:
Now to go shopping for one of those desoldering pumps.
)?Wow.
Out of interest (as I know nothing about caps) - I take it that like for like parts are not easily available ?
If I were to spot a swollen capacitor - how would I know what to replace it with as presumably it would need to conform to the correct voltage as the original (or can I just replace any cap with any cap)?
After the succesful recap of the slot 1 board I set about building a new "main" rig that will cover everything I really play (late dos, early windows).
Specs:
P3 550mhz.
128mb ram
Diamond Viper V550(Riva TNT). Originally a TNT2 but the card is faulty.
Aureal vortex 2
50gb HDD.
Windows 98se.
Not super impressed by the midi on the vortex2 but am looking to buy a dreamblaster x2 one day so that should sort that.
