- 2 Feb 2010
- Crowmarsh
Looks like things are coming on well
Small update and the first use of the shower - oh man what a fantastic decision to get an unvented tank. Will be no heat and we'll have to use the immersion over the weekend but that's ok.
Looking good.Small update and the first use of the shower - oh man what a fantastic decision to get an unvented tank. Will be no heat and we'll have to use the immersion over the weekend but that's ok.
Gas hard lines partially in.
Small but oversized rad for the girls future bedroom. Usefully this allows enough room to the left for a bookcase or something.
Temporarily fitted a new shower too. He's made good the hole in the roof too.
Final jobs for Monday include new rad pipework downstairs and then connecting up the gas.
Very pleased!
Haven't spotted a magnetic filter yet but haven't had a look in the attic just yet. I'm sure there will be one.Coming along well.
I was going to mention to make sure your guys are fitting a magnetic filter (most boilers require it for warranty anyway) and an automatic bypass valve which will save you energy.
Also, are you happy with how they've plumbed the shower in or is it temporary until you can get behind the wall?
It'll be a fair while till I get to decoration so the lads are second fixing everything today, and coming back tomorrow to do a powerflush of the full system.How come you're hanging /second fixing rads? Presumably you're changing the decor and/or getting the room plaster skimmed?
Best to take them off before that but appreciate you may just have them for now then take them off and refit
Aye that makes sense then! Just double checking youre aware. Rads look nice.I'm under orders to get the house liveable
maybe has one internally?and an automatic bypass valve which will save you energy.
B&Q - 863£ for all of them. The hall rad was an oversized 400mm that happened to also be on clearance but the other two were bought to 'spec'/had to be that size so paid full price/no deals to be done.Rads look great! We’re going for the same style downstairs where they’re visible in the hallway and dining room.
Where did you order yours from?
An automatic bypass valve is something needed if the primary circuit flow could be blocked (TRVs all closed etc) without an alternative bypass arrangement but isn't an energy saving device.
Very true, but it can be an energy saver if you just have a non-automatic gate valve with a fixed percentage open as a bypass, like I have currently. There's always some amount of flow returning to the boiler.
Interesting! I am not sure I have any flow issues (he did test it I think - he had two devices). I imagine the pipe coming in has been changed to copper at some point but I am not sure how to "check". I did consider swapping for plastic when I had the drive done but timing was too tricky to arrange it.@dLockers - I would definitely check the mains cold bore size as older houses like the one I have currently could have an original 13mm LDPE mains feeds to the meter which reduces flow considerably. I upgraded mine from 13mm LDPE to MDPE 32mm OD (26mm ID to closely match the ID of 28mm copper) but for 22mm internal cold pipework internally as you've now got 25mm MDPE (ID ~21mm) is ideal. Something perhaps for a later project but an often overlooked item that will improve flow rate if not limited by other pipework in the home and an area plumbers ignore as they just consider pressure.
Indeed, but in practice the boiler then uses less energy to heat back to the output temperature.
