Nope.
Though if the server you're on has 100ms+ latency then you might aswell be playing at 10fps.
Good GPU, good CPU and 100fps+ maxed in ultrawise / 4k its beautiful
You can change your audio settings to party only which helps a lot of the screeching.Is there a quick ‘mute all’ key like there was F9 in Warzone?
Annoying having to listen to teammates in the gulag
I must have that set already as was saying to team mates I had never heard proximity chat work yet so put it down to that. Pre-lobby they said they could hear every other mic in the lobby whereas I couldn't.You can change your audio settings to party only which helps a lot of the screeching.
Proxy chat it great though and useful.You can change your audio settings to party only which helps a lot of the screeching.
Apparently just running them over is easier.Who’s done the DMZ radiation challenge for the M13? Fighting bots with aimbot![]()
You’d think so but the armoured trucks have the manoeuvrability of a Boeing 747 trying to turn around in a Tesco car park.Apparently just running them over is easier.
Doing safegracker and Intel missions in BR is pretty rapid at levelling up.Any tips on quickest way to gain XP and level up?
That's what I did, use the armored truck to run the chemist over, quickly jump out grab the weapon and drive straight to an extraction point.Apparently just running them over is easier.
Unfortunately he's not always out in the open. Some spawns put him in a house surrounded by bots. Pot luck I guessThat's what I did, use the armored truck to run the chemist over, quickly jump out grab the weapon and drive straight to an extraction point.
The M13B is really nice to use.
Similar today, we either get into 30-50ms lobbys or 100ms+ which is unplayable. Seems to be one game 40 then another is 100-130.Server latency was terrible last night. 80-130ms plus with 200ms plus spikes. Should be sat around 40ms.
Frame rates are great but latency shouldn’t be an issue these days.
Two of us playing. Did the hostage rescue. Imeeditely ran into a full squad of people. Next to no armour/ ammo wipe out.DMZ is pretty fun. Got ambushed hard at extract a couple of times. Need to take it a bit more seriously.
