New Power Supply?
6 Aug 2013
I'm pulling together parts for a new build, which is looking like:
4090
13XXX (Not sure on i7/i9) yet
Not water cooled.
I have an XFX Pro 1000W power supply, which on paper being a 1000w should be ok. But it's now 10 years old. Is it time to replace it (albeit it works fine) or will it suffice for a few years yet on a new build?
Thoughts appreciated?
XFX PSU's were rebadged Seasonics, which were the best at the time & one of the best now. PSU's do degrade over time, so it's gong to be hard to say whether it should be replaced. Give it a go, if there any stability problems then buy a new one.
XFX PSU's were rebadged Seasonics, which were the best at the time & one of the best now. PSU's do degrade over time, so it's gong to be hard to say whether it should be replaced. Give it a go, if there any stability problems then buy a now one.
I didn't know that. That's a bit of a positive result.
I was leaning to the plan of keeping then upgrading to a ATX3.0 when more is available. Thanks for the input.
Does it have enough connectors for the 4090 adapter cable? I'd imagine a 1000 watt psu would, but it's a 10 year old design.
If it were me and I was spending a lot of money on a new build, as you clearly seem to be, then I'd definitely go the whole 9 yards and get a new PSU, normally I'd say you'll be probably be fine with what you have, but I just think in your case it makes sense to support the build with a new top quality PSU.
Gold rated is plenty good enough by the way, anything rated above is just marketing, there's no discernable real-life advantage to anything rated higher.
So slight update. I can't find any of the spare original cables, which isn't suprising as I've not needed them for all these years.
The PSU has 12pin slots, that came with 12pin to 2 x 8pin PCIE. The challenge now is getting cables for them.
I've been looking to see options for a new PSU, but it appears stock availability now is limited and not sure which way to go. I don't really want to dump £300+ on an ATX supply, versus a new ATX 3.0 albeit availability is the problem on the 3.0's.
It's never easy.
