Call Of Duty: Modern Warfare / Warzone (Battlenet ID's in OP)
t actually sounds great for a nice change of pace. I just don't know where to start, solo sounds like suicide at the start, especially with the exfill banditss lurking to rob you at the end so I reckon I need one or two others but randomers cannot be trusted.
Trying to convince a few mates to buy the game but they don't buy game fully price but this is one is worth it.
On the point of giving up on multiplayer.
Aim assist is broken, riot shield is stupidly OP and no effective counter for it and games just degenerate into endless flashbang/gas spam most of the time.
Semtex, drill charger and thermite immolate the shield. I've actually started using a shield for my shotgun class cos it shields your back (kind of, if you don't crouch). If you want to see the disadvantages of the shield just play it.
Can be good on hard point, HQ and domination alright. Plus they're is a pretty to negate the flashes and gas. Custom loadouts are great
If someone kills the chemist and exfils from the map, is that it and you have to join a new game to try again?
Or does he spawn for every team in the map?
Go in with someone who has the m13 In their inventory. Get them to drop the gun, pick it up and exfil.
Thanks for the tips. I've seen thermite recommended before but feels annoying having to cart that around instead of an alternative lethal just to deal with shields.
I actually don't have too much of a problem with shields being used 'defensively' for things like Headquarters or Hardpoint, it's the ***** running around like idiots just ramming you with it all the time whilst trying to knife you.
Warzone 1 Under Maintenance until November 28th,Very convenient that, they know so many people would just go back to playing WZ1 or something :D
Its so they could move all devs to WZ2 for ironing out issues.
WZ1 will be back then with the devs back but Caldera only. Renamed Warzone:Caldera. No rebirth either.
Is anyone on here called Cannonfodder?
Yep, not sure who but he/she added me also
First win in a solos tonight! What the hell do you do with the 3 plate vests? Can you even put them on?
Final circle and I had 3 3 plate vests but had only 1 plate of armor in not knowing what to do with them. Is there a way to use them or do you have to break them down first or something
Also got your add request I think. I was curious about Cannon fodder as it always shows they are playinging through Americas region.
Yep, that was me. Not sure who Cannon fodder is but the thread is public view so could be anyone.
Anyone know what an 'AQ Soldier' kill is? The solos I had 9 operator kills and 5 AQ Soldier kills. Does that mean I only killed 4 real people and 5 bots?
Yeah I believe it is an AI enemy according to Charlie Intel website.
