Hello!
Let me start off first by saying I’m in no way a computer person and infact this is my first “expensive” pc as before all the ones I had were cheap small ones from currys so I’ve very little idea about what parts are good and so on.
Because of this I bought a prebuilt PC in hopes of being able to run games a bit easier (nothing fancy just aiming to not play on lowest graphics possible) but I’m having major issues with my power supply.
I sent the PC back to overclockers in October due to the PSU blowing and had them look at it and replace said part, it was returned to me the 15th of November and I turned it on for the first time on the 18th to update anything needing updated and logging into stuff like discord again before shutting it down
Today (20th of November) i turned it on again only for it to pop and let off a huge spark - PSU had blown again
Is there anything I can do apart from fight with overclockers again to try to get a higher quality one?? I genuinely didn’t do anything during the single time I turned it on to warrant the one overclockers had put in to blow again so its quite frustrating.
I’ve attached the pc specs that were on my invoice below if that helps for anyone since I’m not the best with computers haha
PC SPECS
OcUK Gaming Falcon - Intel Core i3-10100F, AMD Radeon RX 6500 XT Gaming PC
Commodity:8471 49 00 00 Origin:GB
Kolink Inspire Series K2 ARGB Micro-ATX Case - Black Window
Kolink Core S Series 700W 80 Plus Certified Power Supply
*Build Promo* Intel i3 10100F BX8070110100F
Sapphire Radeon RX 6500 XT Pulse Gaming 4GB GDDR6 PCI-Express Graphics Card
Crucial MX500 250GB SATA 2.5-inch, SATA 6.0Gb/s 7mm Solid State Drive
Seagate BarraCuda 1TB 7200RPM SATA 64MB Cache Hard Drive - *System Stock*
Gigabyte B560M DS3H V2 (Socket LGA 1200) Micro ATX Motherboard
Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Chann
ASUS PCE-N15 300Mbps Wireless N PCI-E Adapter
Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
PC SPECS
