It's not the worst day. At this point, half the reason I bother with watercooling is getting to mess around with it!
Lol yep, my last change took basically 2 days.Very true, I do like a good project but I always know that full upgrade day is a pita!
That satin plexi tubing is so difficult to work with as it cracks so easily.
Oooh nice satin tubing. Please post a pic when it is all done. I may consider satin tubing in the future.
Very nice and thank you for the pic. With the normal clear little loop I can see the difference and I do like the satin tubes. What brand is your satin tubing and any recommendations ?
I do like that satin tubing
Thats what I`m waiting for, plus the 7800X 3D and hopefully the Lian Li 011D XL EVO all appearing early next year then I`ll build a new system.I am waiting to see if I can snag a 7900xtx before I think about maintenance. New gpu and waterblock would make it feel more worthwhile rather than just a general clean.
Well I just checked to see what was available and it seems there is only 14mm and 12mm satin tubing and I have 16mm fittings. If anyone knows of 16mm satin hard tubes then please inform me but if it is not available I will have a practice sanding on my PETG 16mm tube to see if I can get the same effect. I have seen some vids of a guy doing this and it looks more time consuming than difficult and the bonus is I get to use PETG and not acrylic.
