Ta.
Today was my 2 monthly visit to eye hospital. I have finally got them to give me early morning appointments so got there for 8.45 - Stop at desk and log in and they tell you to sit over there.
A very nice nurse came out and shouted John Smith come with me - They sat me down in a chair in front of what i thought was a lens but it turn out to be a blast of air on your eyeballs.- Have to say these new ones do not blow your eyeball out -just a light puff. -I was then asked to read the letters on wall - Managed a few with bad eye but could easy read third from bottom and then a few from last two lines.
They then put some of those drops in my eye that stings like hell then told me to follow the yellow brick road. - There is a yellow line painted on floor that takes you to the eye clinic so sat down on chair and found i was surounded by loads of Gerry hat tricks.
Got called in for pictures to be taken of both eyes.- sat down again -Then 10 min later got call to top dog- She was very pleasant and asked if I was happy with my left eye -Ahhhhhhhhhh -My right eye is the problem - Seems there is slight bleed on left eye now so she told me they are now using this as a marker for future pictures - anymore bleeds and it's a jab in left eye as well - Just what I bloody want.- Look up and in went a dose of anasthetic - sat down again.
Got called to nurse or Doc who was giving the jabs - Quick chat and more anasthetics then they dragged me off to operating room - lay on bed and had hat put on -some wads to hold liquids then shut your eyes and load of yellow liquid was squirted on my lids -A wet cloth then wiped it all over till it was clean then she said look up -wam a eye lid clamp went on -look down and same thing - I can't blink -Don't worry it's OK -
I was now thinking last time they put about 9 doses of anasthetic in but today ony three - In she came with the needle and said look at her mate and as I did that she jabbed needle in and emptied it in my eyeball - That was easy - got cleaned up and clamp out and she said ok sit up ---- That is when I saw it. - WHAT is this - I have two round rubber oil seals in my eye - Don't worry it happens all the time - Not to me this is first in about 15 jabs - It will go in a day or two. - Imagine you have a thin metal/plastic rod sticking out of your forhead and on the end is a piece of cotton holding up two rubber oil seals tied together dangling in front of your eye - Thats what it looked like but it's in my eye.
A bit of googling said it is Weiss ring or something like that and it is air bubbles. It doesn't hurt but when you lean forward these two rubber ring float up into your vision -look down and they drop below your lower lid.
And to top all this off I had to let wife drive us home -That is worse than eye jab.
So ladies and gentlemen - every year get yourself to opticians and get your eyes tested -Or if you notice a problem - it might cost a bit but I can assure you all your eyes are worth ten times that - Your eyes are the only part of your body they can't replace. You can't read or write -sit at PC on here or gaming -driving- footy -golf -snooker or any sort of hobby - cooking -making tea or coffee -the list goes on.
