ThanksFor gaming the 5800X3D is often better. Have a look at this video and jump to the benchmarking sections
£350 on sale now...hmmm lol
It's been around that price for quite some time. As this CPU competes very well with the latest Ryzen gen 5 CPUs for gaming I don't think it's likely the price will go down much more for the foreseeable future.Thanks
Anyone seen the 5950x at a good price? I feel aggrieved paying over £500 for one where for an extra £50 I could get a 7950x (albeit with the additional cost of motherboard and ram)
Hi,
With the prices of new platforms as they are at the moment I have decided to replace my good old 3900x with 5950x that I was able to grab for £430. The idea is to skip the first AM5 series entirely.
I do have temperature problems with the new CPU though.
I'm using Alphacool 280mm AIO in a well ventilated case.
All 32 thread load is ~70*C with the fans not even spinning fast.
HW Info shows: CPU package power at 145W, CPU VDD 100A, clocks ~4375MHz for all cores under load.
With single thread load its 77*C but with 2 threads running its hitting 90*C that behavior is the same all the way to 5 threads. Then with 6+ threads under load the temperature starts dropping again.
The fans are at full speed in that situation which is loud and annoying.
I have put fresh Arctic Silver 5 on the new CPU and the cooler is fully tightened (it has springs on the mounting screws so pressure should be even)
I'm feeling like I'm already on AM5 lol. Any ideas why I'm seeing 90*C on that thing?
Hi,
I'm using prime95 custom test with 1344K FFT size without disabling AVX2. Tested just now with disabled AVX2 and then p95 uses just AVX - temps are few *C lower on 2 threads ~86*C instead of constantly hitting Tjmax.What load are you using to tests temps? Is it something like prime95 and is it an avx load?
What memory speed are you running also.
How old is the cooler? I know on my artic AIO they released an offset bracket after the 5000series released for better temps.
The AIO was bought in July 2020 so not very old.
Memory is a Corsair Vengeance 2x32GB kit 3200 and runs without OC
Yes, XMP profile is loaded and that indeed raises voltage above default. The modules run at 1.35VCooler is old enough that the cold plate may not be making great contact with the core chiplets due to them being a decent bit off centre, an updated offset mount may exist for it. Artic must have released one for a reason.
I asked about the memory as if you loaded up an XMP profile it may have set the memory controller voltage higher than needed which all adds to the heat you are trying to dissipate.
					www.alphacool.com
May be worth looking at the VSOC voltage if you can find it in your BIOS or you could use a program like zentimings and post up a screenshot. It's what I meant by memory controller voltage.
I don't think it's going to make a huge difference dropping it though, it's why I kept asking about the cooler.
	I didn't realise until I tried your custom test just now, but it seems Prime95 now sets the core affinity to the first 'x' cores by default, so a 2 thread P95 run will be locked to core 0 and core 1. At least compared to an old v29 download I had, which just left it up to the Windows scheduler, which in turn mostly used the "best" cores.This illustrates that the cooling is doing just fine with 145W 32 thread load. Way lower fan speeds and nice temps compared to 2 thread load that is just bonkers - with cpu package power ~100W although concentrated in one chip/CCD I worry that the issue could be more chip-to-ihs thermal dissipation than it is ihs-to-waterblock problem.
IMHO, your screenshot show a normal 5950X to me. With a stock PPT, i'd most certainly expect a 2T workload to be higher temperature than a 32T workload.I have a feeling something is not entirely right with the cpu itself or how the mobo drives it.
Attaching HWinfo screens comparing 2t and 32t load
This illustrates that the cooling is doing just fine with 145W 32 thread load. Way lower fan speeds and nice temps compared to 2 thread load that is just bonkers - with cpu package power ~100W although concentrated in one chip/CCD I worry that the issue could be more chip-to-ihs thermal dissipation than it is ihs-to-waterblock or AIO efficiency problem.
That is a valid point with power denisity. And I have expected higher temp with less cores loaded. I guess i did not expect to be as high (hitting limit)IMHO, your screenshot show a normal 5950X to me. With a stock PPT, i'd most certainly expect a 2T workload to be higher temperature than a 32T workload.
Under heavy multicore a 5950X is super power limited, so the clocks and voltage drop. Even though peak power is higher, the power denisity is much much lower.
You can see it in your screenshots.
2T = 63.7 W core power / 2.3 busy cores = ~27.7 W per core
32T = 111.8 W core power / 16 busy cores = ~7.0 W per core
Easy to see why the 2T CPU core temps are way way higher. Your cooler has the cooling capacity, but the heat density is so high the heat doesn't get out of the chip fast enough through the STIM/IHS. This is a 'feature' of modern CPUs unfortunately.
