But before I get too comfortable into thinking I've ordered everything and I can just sit back and chill while I wait for the components to arrive, did make a bad choice in going for 6400 DDR5? It seemed like a good deal at the time?
amd have stated that ddr5 6000mhz is where you should aim for amd 7000 series as any faster may cause you to loose performance or you may get odd behavoir booting or within windows, plus games may freeze and crash, i have ddr5 6000mhz dominators expo kit, a 5600mhz 32gb kit will do and upto 6000mhz should really be the max. if i were you i'd send the 6400mhz kit back and exchange for a expo kit in the 5600-6000mhz range.
