Ever since I built my new pc with I've been having pops in all my audio ports including when sound is coming out my monitor. I can't quite figure out how to fix. It will happen randomly when listening to various audio sources and essentially.
I did recieve a faulty 7950x from amazon which caused bsod and was able to get that replaced and haven't experienced any problems really apart from popping and very rare stutters.
What I have tried:
PC specs below:
Motherboard ROG CROSSHAIR X670E HERO
Cpu: AMD 7950x
Cooler: Be quiet dark rock pro 4
Ram: Trident Z5 Neo DDR5-6000 CL32-38-38-96 1.40V 64GB (2x32GB) AMD EXPO
GPU: Zotec 4090
PSU: Be quiet dark power 12 1500W
Case: Fractal Design Define 7 Solid
What I have tried:
- Reinstalled windows and tried both 10 and 11
- Enabled / disabled audio enhancements
- Tried every compatible audio format (bit rate and Hz)
- Ran Troubleshoot --> Playing Audio multiple times; following prompts as applicable
- Un-installed / re-installed audio drivers (directly from motherboard manufacturer).
- Disabled on board audio and only had audio coming out the monitor and still got popping
- Running bios on defualt settings
- Fresh install of windows with 0 drivers still had popping
- Change power state option to high performance
PC specs below:
Cpu: AMD 7950x
GPU: Zotec 4090
