- 1 Oct 2020
It's possible to get more kills than deaths in a COD game? Never knew that!
Impressive stuff!
Impressive stuff!
Blimey 44 kills is a lot well done!
Here's the best FPS score I managed at 1080P lowest settings + CAS on the 4090. Would need a 3DVCache chip to get a better score here.
Here's the same test but with recording hit included from video capture.
The game looks stunning to my eyes, i do love the sound of a well placed HeadshotAs said already, graphics is quite a big step up from MW2019, even multiplayer.
Im enjoying using the different guns to unlock attachments. Eg the Icarus lmg and FTAC recon battle rifle. Guns i would have never of used but are quite enjoyable.
I play with settings maxed (no dof or blur) in 3440 x 1440 on an Acer X34 Gsync monitor.
FPS wise I was using a 3080 and getting 70-100 (capped at 97fps) in games. I now have a 3090 Ti and multiplayer is never below 97. Benchmark shows just over a 30% increase in fps compared to the 3080. Of course i would love a 4090, but got the 3090 ti for a a reasonably good price. Im capped at 97fps too, so the extra frames would be wasted (unless i upgraded to 4k / higher Hz screen.
Pictures don’t do it justice. The general game effects on the guns and sound is fantastic. Down to things like ejecting used shotgun shells and reloading new ones.
Yeah I saw that, water cooling and 13900K would be fast. Reckon 3DVCache will be very fast in this too just like the 5800X3D.Some impressive numbers there LtMatt
Was watching the framechasers video and he was getting 491 with the 13900k but i am holding off till next year myself as want to see what the 7000 X3D brings to the table ( should be mega going by your result ) and also see what 14th gen has to sayCurrently though plays very well on a 10900k and will hold 240fps at 1440p if not gpu bound on some levels , around 210-220 when bound. mainly play at 4K though where it is a lock 120 fps
Have rerun the benchmarks as since I posted that they have updated the benchmark run to better represent what it's actually getting, seems the 1st version of the benmarks were giving higher readings than it should but seems a lot more realistic now as comparing the score with riva benchmark running ontop gives almost identical scores.Just thought I would post this before the 4090 FE arrives in a few hours, so i've got something to compare it too
This was on the Extreme graphics settings, if that affects the Benchmark (Seems strange it doesn't list what mode you are using)
Weird that my 13700k is getting lower CPU scores than @Jay-G25 on a 10900K
OK - 4090 FE benchmarked at 75% power limit (I forgot to turn it off)Have rerun the benchmarks as since I posted that they have updated the benchmark run to better represent what it's actually getting, seems the 1st version of the benmarks were giving higher readings than it should but seems a lot more realistic now as comparing the score with riva benchmark running ontop gives almost identical scores.
Have run both stock and game stable oc
yes mate using the extreme preset , your results look spot on to meOK - 4090 FE benchmarked at 75% power limit (I forgot to turn it off)
Got similar results to your stock run:
Are you using the Extreme preset?
Stupid question
From screenshots above It looks like MW2 has its own build in fps counter and hardware monitoring? Where is that option?
Doesn't OBS use the new Nvidia AV1 capabilities now?Performance cost of recording is very high using Shadowplay compared to using AMDs ReLive recording feature, so these were all captured at 30 FPS.
Don't know, but may consider using it if it's simple enough and perf is better tbh.Doesn't OBS use the new Nvidia AV1 capabilities now?
Ahhh it may be more streaming based.Don't know, but may consider using it if it's simple enough and perf is better tbh.
I think I only noticed the big jump in FPS a couple of times, it was lower on 1st launch then around the same after that.I got some dev errors too. Not ran it for at least a month maybe more, but last time I ran it there are were no dev errors. However I will say that my FPS are consistent and change by no more than 1 FPS each time i run it.
