Solar panels and battery - any real world recommendations?
I know during the summer/autumn i was checking the roof late in the evenings and i was still get full sun at around 8pm……no shading at all, but never checked in the mornings. So will do that when we get closer to spring.
i cant post pictures, otherwise i would post up todays power curve.
Its something close to this:
So 500w @ 7am and same at 6pm. Obviously scale it to your spec.
Getting this error - so clearly something is wrong.
2022-12-01 15:40:09.888 WARNING (MainThread) [homeassistant.config_entries] Config entry '*****' for pvoutput integration not ready yet: PVOutput has no data available; Retrying in background
Is there a more step by step guide you can point me to?
I'm just setting this up. Got exactly the same issue. I cant see anywhere that I can tell PVOutput what sensor to use to report my generation?
Cracking sunny day again, shame I can see WTF is going on. :(
Evening readings from the solar generating meter will give you daily figures for the total produced for that day.
A pain I know, but at least you will have daily figures going until it's sorted.
Thanks. I found that and gave up at part 4.
Those instructions aren't great especially if you don't know what "famous configuration" file it's talking about.
You need to add the shell command block to your configuration.yaml file near the end, which is in the root of the home assistant configuration folder, like below image. This is my Givenergy one which may look a bit different, you also need your API key and your Id values where I have shown example with redacted.
But the principal is similar, once you've populated this shell command section it will appear in homeassistant as an action that can be done on a schedule, you may need to restart homeassistant after adding this bit of code.
Yesterday was much better for us, not so good today. One thing I've realised today, is that 2022 has been our best solar year so far, previous yearly high was 4.509MWh in 2020, currently at 4.579MWh and still 20 solar days to go.
