- 28 Sep 2014
- Scotland
Wow another AMD CPU mouse, audio, graphics lag thread.
I tried to helped other OP from other thread https://forums.overclockers.co.uk/threads/mouse-lag-choppy-audio-choppy-graphics.18963485/ but not heard from OP so I guess OP had enough and opened window to throw out most expensive PC with Threadripper 1900X.
I am still at loss how to fix AMD CPU lag issues that could caused by buggy FTPM, chipset driver, USB driver or AGESA bugs.
Maybe it is USB ports issue?
www.reddit.com
OP comment about CPU USB and CPU provided 4 USB 3.0 ports made no sense. Accorded to B450I GAMING PLUS AC manual stated:
It seemed OP fixed issue by connected keyboard and mouse USB cables to 2 USB 3.1 Gen1 ports AMD CPU used these ports.
www.pugetsystems.com
I read ROG STRIX B550-A GAMING manual found:
Which ports did you connected your keyboard and mouse?
Try connect your keyboard and mouse cables to 2 of 4 USB 3.2 Gen 1 ports that CPU likely used.
Really hopefully that will fix your issue.
If it will not fix issue. Try download MSI mode utility V3.
www.igorslab.de
Reddit - Dive into anything
AMD® CPU
4x USB 3.1 Gen1 (SuperSpeed USB) ports (2 Type-A
ports on the back panel, 2 ports available through the
internal USB 3.1 Gen1 connector)
AMD X570 vs B550 vs A520 Chipset Comparison
AMD has three current chipsets for their mainstream Ryzen processors, each targeting a different segment of the market with appropriate features and pricing. What is the difference between each of these chipsets, though? Knowing that can help make sure you get the right motherboard for your next...
³ Ryzen CPUs also provide four USB 10Gbps ports
Rear USB (Total 8 ports)
2 x USB 3.2 Gen 2 ports (1 x Type-A + 1 x Type-C®)
4 x USB 3.2 Gen 1 ports (4 x Type-A)
2 x USB 2.0 ports (2 x Type-A)
Front USB (Total 6 ports)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Solving “unexplained” interrupt problems: Message-Signaled Interrupts (MSI) against sound dropouts, USB problems & Co. | Practice | igor´sLAB
If the sound card drops out or cracks, USB devices do not work or only work sporadically or the performance drops, then interrupt conflicts are usually the cause. This is something that Windows users…
Windows: Line-Based vs. Message Signaled-Based Interrupts. MSI tool.
... or another attempt to improve latencies Little bit of theory: ***** From "Windows Internals" by Mark Russinovich, David A. Solomon, Alex Ionescu Line-Based vs. Message Signaled-Based Interrupts Shared interrupts are often the cause of high interrupt latency and can also cause stability...
forums.guru3d.com
