- 27 Mar 2013
How much of a difference does lagging make? To clarify, I've got a short run of copper pipe, maybe 30cm in the garage. I've put lagging on it, but the garage is currently about 0.5 degrees. It's attached to the side of the house, but is only single story (not integral), the pipe is in the corner of 2 interior walls, but in the garage if that makes sense (might stick a jpeg in). So how cold does it have to get before it will freeze? I'm going to borrow a thermocouple from work and log the temp overnight to see the difference, but I am slightly concerned (although it wasn't lagged last year and didn't burst). Sorry its a bit vague.
So the left wall is a stuff wall from the new extension (so should be a decent amount of insulation), right wall is the original but of the house but it's cavity wall. The lagging is a little bit taller than the pipe, but gives it some scale. The only other thing is that the pipe is so close to the wall that I can't get lagging round that edge <10mm gap.
