- 14 Dec 2022
- sheffield
I think it is normal for cpu cores to reach 100 percent in cases though when gaming. Some cases though it’s like 80% in the cores and still stutters. I am desperate to resolve it!no idea why tbh
could it be my ddr5 ram having cas latency of C40 5200. not able to send the info to the cpu quick enough then causing fps drops?
Ye doubtful it’s that and I have had the issue with other monitors as well.I shouldn't think so, especially not at 4K. 360p with a 4090 then yeah, maybe![]()
i have ran this and there does not seem to be an issue. i feel like i am going crazy and its every game. not every game is as bad for example warzone maybe has an fps from every 5 mins that causes a stutter and red dead when it goes into the 80s as 1% low i get a stutter.Doesn't hurt to run LatencyMon to see if a driver is causing the issue.
the same is happening now in RD2 - the game gets these random lows down to like 50fps. is this my ram being to slow with a CAS 40?
Hello,I'd suggest you run some score based benchmarks on your CPU and graphics card to check 100% that your system is performing correctly, because it's really hard to know what exactly you're referring to ('stutter' means completely different things to different people).
Is a 4090 a monster at 4K and a capable card even with everything turned on (including ray tracing)? Yes. Will a 4090 never dip below 60 fps in the latest games/updates? No. The 4090 does come bloody close, but no graphics card has mastered 4K with RT yet (nor have the game engines, tbh).
Okay so I had to replace my cpu as there was an issue in it. Didn’t seem to change performance as switched for a 13900kf and j am still experiencing the random fps drops.
What is normal amount of stutter. For example spider man might stutter once ever 5 minutes is this normal? Farcry seems okay at 60fps locked but still occasional stutter.
What do we class as normal regarding the amount of stutter. My games are not just stuttering all of the time it’s every few minutes or so I get one fps drop. Cpu usage on 1 of the cores reached 85 percent during gameplay which I think is normal???
It’s starting to drive me insane though as I just expected flawless gameplay to be honest all the time
I am using 980 pro SSD so things seem to be fine with that regard. I don’t get it when loading into a level it’s when the fps suddenly drops lower it stutters. I have completely rebuilt the pc with all new components so I genuinely so confused…On a hard drive and a slow SSD, it's fairly normal to get occasional stutter while things are loaded, especially at the start of a level, for example. But, what you're describing sounds more common than what I'd expect.
How normal are stutters just during game play. Please note they are like microstutters not huge freezes
So I actually just put another SSD in from gigabyte that was the same spec and I still encountered the issues. That’s how I rules out a faulty SSD and yes I have ran Samsung magician and it all came back normal.Have you checked the event viewer for disk errors and ran a full scan via Samsung magician?
During normal gameplay, if you're using settings that the computer can handle reasonably well, then I'd expect to see very few, but it does depend on the game & the engine, some games are more prone to hitches than others.
Would you say I should not be putting everything on ultra at 4k?
My 3DMark score seems pretty normal as well Right? Cpu is only at 60-70 degrees when gaming as well!Well, you're more likely to encounter issues (fps drops), yes, but it is hard to say for definite what's normal, because it really depends on the game and then it can even depend on specific things, like levels, number of players, particular effects on the screen, etc.
thanks for the reply.
i am actually on windows 11 already so this is why its so strange. basically i notice some of the CPU cores reaching 100% when gaming... not sure if this is normal but i get this awful stuttering when it happens. has anyone got a suggestion or solution to this?
thanks
