OcUK Staff
- 1 Apr 2014
- OcUK HQ
With a Lian Li Lancool 216 chassis, you’ll have a case perfect for a modern powerful gaming PC, thanks to its innovative airflow design. The Lancool 216 provides components unimpeded access to cool air, thanks to larger mesh panels on both the front and top of the chassis. Furthermore, Lian Li has totally redesigned the front fan assembly. It now includes a pair of 160mm fans housed in a specially designed shroud that channels air directly through the fans, cutting down on turbulence. Inside the main chamber, there are plenty of hardware options, including support for E-ATX motherboards, full size GPUs, and 180mm CPU coolers. Additionally, the Lancool 216 has been enhanced for maximum airflow by including an external bracket that enables you to install a 120mm fan to pull air across your GPU to maintain optimal temperatures.
Lian Li Lancool 216 Mid-tower PC case - Black @ £109.99 inc VAT https://www.overclockers.co.uk/lian-li-lancool-216-mid-tower-pc-case-black-ca-7b8-ll.html
Mid-tower case, High-airflow design, Dual 160mm fans included, Two locations for front I/O, Two modes for motherboard setup, Improved GPU cooling with external fan mount
Only £109.99 inc VAT.
ORDER NOW
Lian Li Lancool 216 Mid-tower PC case - White @ £114.95 inc VAT https://www.overclockers.co.uk/lian-li-lancool-216-mid-tower-pc-case-white-ca-7b9-ll.html
Only £114.95 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
Cheers
