- 13 Apr 2013
- La France
Every once in a blue moon, despite having lived and driven in an LHD country for four year, I find myself about to pull out of a car park onto the wrong side of the road.
I've never brake checked someone and won't normally pull over, etc. for them but I had someone doing it so badly the other day, even setting off the rear proximity sensors at times, I did multiple tap the brakes just to illuminate them and when that didn't work pulled into the next junction when I had a chance because it was just so likely to result in an avoidable accident if anything unexpected happened. Funny thing was I think they thought I was going to road rage them as they stopped short, hesitated then backed up to take the other road off instead rather than pass me :s
Was the car on French plates? Pulling right up to your rear bumper before moving out to overtake is standard here.
Saw a massive transporter pull down a road near me that I knew would be hell for the driver. Didn't see him come back so he must have made it so fairplay!When I first started trucking I got lost and needed to stop for a break and in a panic I thought I was going past the point of return to find somewhere to stop before running out of hours. Ended up swinging into a petrol station to try and turn around only to find out I was too tall to fit under so had to reverse out into rush hour traffic. Luckily the guys in the station gave me a hand stopping the traffic so I could get out. Ended up causing a bit of a jam and lots of angry faces behind the wheel but you live and learn!
With a car you can get out of most things but it is very easy to get knee deep in excrement in a truck very quickly!
What we need is a universally recognised hand sign for "that was my fault, sorry mate" as a wave doesnt quite cut it if they also dont see your face/body language. If you blantantly pull out on someone, and they see your wave as "thanks for letting me out" its even more irritating.Going up a slip road behind a very slow car who didn't realise they are meant to be used to get upto traffic speed to allow easier merging.
Anyways, I took a look pre-merge and all seemed fine so I accelerated hard and went straight into lane 2 (3 lane m-way) to only just avoid hitting a large Range Rover whos bonnet was pretty much at my rear 1/4.
I hadn't even seen him slightly further back already in lane 2. Thankfully he took action to prevent the collision and I put my hazards on and gave a very apologetic wave out the driver side window... The chap was very understanding considering - he gave a wave back realising it was a screw up and not intentional.
I don't mind people that make mistakes as 5hey do happen but, if you do, then at least apologise rather than actually giving aggro (rude gestures etc) to the vehicle you nearly hit... It turn you it from a genuine mistake to you being a ****
In 11 years driving so far I've clipped someone's wing mirror. Going to shift some blame on this one as person on the other side of the road decided to proper squeeze me despite having loads of room. (I could have stopped though)
The other was straight up me reversing into another car not looking properly (luckily/unluckily) my reverse light hit their tow bor. my car needed a new bumper while theirs was fine.
