- 2 Sep 2013
I agree.
Given that on ethernet you were able to get 930 up/down on the Velop, it's unlikely to be the ethernet cable at fault.
This leaves two options; a setting on your Asus Router you've forgotten about that is doing this limit, or the ethernet port is damaged/buggy.
So first thing I'd do is try another ethernet port on the Asus Router if there is one, and try again on the ethernet speeds. If still the same, try one more port (if available, just to eliminate chance). And if still the same, it's very likely to be the Asus Router having a setting on it enabled then or limited; perform a factory reset of it as you won't know what you've enabled/disabled or limited and restart from scratch for new settings.
If you get full 930 up/down on another port, then that port you were originally using was at fault. Tape it off and never use it again.
