Chatgpt and Programming
3 Oct 2014
Has anyone used ChatGPT for programming, it has helped me solve two problems today. One using an obscure library to link into an API from an unrelated website.
It would have taken ages to piece it all together manually.
An example just off the creating a bash script and appending some text to a file, then asking it to do it a different way.
I asked it to write something for me in Python for the Pi and it was spot on, even loading the appropriate libraries for me to access the GPIO pins I wanted to. It's rather clever.
Does it write code and test it 'virtually' before spitting out an answer?
Don't think it tests it but it should be on the user to do so, just like when you get an answer from StackOverflow.
Its a great tool to build the core of what you want and you can tweak it.
I'm not familiar enough to verify its correctness, but that's very cool regardless. Certainly better than any chat bot I've used before.
Hmmm, this is really interesting. Could it do mods to games or find the cause of game crashes?
That's pretty cool that it can write code like that.
I wonder in the future if a version will ever get to the stage of being asked to create a game and you can specify everything and it would mod it as it went along.
I asked it to write some code and then write a test class to ensure 75% coverage. No issues. I wouldn't trust it blindly, but if you know approximately what you're looking for it to do...
write a simple unreal engine subsystem
Sure! Here is an example of a simple Unreal Engine subsystem that logs a message to the screen every time it is updated:
C++:
#include "CoreMinimal.h"
#include "Modules/ModuleManager.h"
#include "Engine/Engine.h"
class FMySubsystem : public FDefaultGameModuleImpl
public:
 virtual void StartupModule() override
UE_LOG(LogTemp, Warning, TEXT("MySubsystem has started!"));
 virtual void ShutdownModule() override
UE_LOG(LogTemp, Warning, TEXT("MySubsystem has shut down."));
 virtual bool IsGameModule() const override
return true;
IMPLEMENT_PRIMARY_GAME_MODULE(FMySubsystem, MySubsystem, "MySubsystem");
This subsystem can be added to your game by adding it to the DefaultEngine.ini file in the [/Script/Engine.Engine] section:
C++:
+ActiveGameModules=MySubsystem
When the game starts, the subsystem will output the message "MySubsystem has started!" to the log, and when the game shuts down, it will output the message "MySubsystem has shut down."
Well, not a bad effort, but it's fundamentally misunderstood the problem, as what it has done is create a Module called FMySubsystem, rather than create a USubSystem.
The code works though, kinda impressive it knows the Unreal API.
I asked for a USubSystem, not a module
I apologize for the mistake. Here is an example of a simple Unreal Engine subsystem that logs a message to the screen every time it is updated:
Copy code
C++:
#include "Subsystems/GameInstanceSubsystem.h"
class FMySubsystem : public FGameInstanceSubsystem
public:
virtual void Initialize(FSubsystemCollectionBase& Collection) override
UE_LOG(LogTemp, Warning, TEXT("MySubsystem has initialized!"));
virtual void Deinitialize() override
UE_LOG(LogTemp, Warning, TEXT("MySubsystem has deinitialized."));
virtual void Update(FWorldContext& WorldContext) override
UE_LOG(LogTemp, Warning, TEXT("MySubsystem is being updated."));
Copy code
C++:
+GameInstanceSubsystems=MySubsystem
When the game starts, the subsystem will output the message "MySubsystem has initialized!" to the log, and when the game shuts down, it will output the message "MySubsystem has deinitialized." Every time the subsystem is updated, it will output the message "MySubsystem is being updated."
Ok, it got there. Default to GameInstanceSubsystem, interestingly.
Impressive! I'll probably use this to stub stuff out
write an Unreal UWorldSubsystem that can record a list of actors and call an update method on each one every frame
Certainly! Here is an example of an Unreal Engine UWorldSubsystem that maintains a list of AActor objects and calls the Update() method on each one every frame:
C++:
#include "Engine/World.h"
#include "GameFramework/Actor.h"
#include "MySubsystem.generated.h"
UCLASS()
class UMySubsystem : public UWorldSubsystem
GENERATED_BODY()
public:
UMySubsystem();
virtual void Initialize(FSubsystemCollectionBase& Collection) override;
virtual void Deinitialize() override;
virtual void Update(FWorldContext& WorldContext) override;
void AddActor(AActor* Actor);
void RemoveActor(AActor* actor);
private:
TArray<AActor*> Actors;
UMySubsystem::UMySubsystem()
void UMySubsystem::Initialize(FSubsystemCollectionBase& Collection)
Super::Initialize(Collection);
void UMySubsystem::Deinitialize()
Super::Deinitialize();
void UMySubsystem::Update(FWorldContext& WorldContext)
for (AActor* actor : Actors)
actor->Update();
void UMySubsystem::AddActor(AActor* actor)
Actors.Add(actor);
void UMySubsystem::RemoveActor(AActor* actor)
Actors.Remove(actor);
Intrigued, I gave it a more challenging example.
write an Unrealengine UWorldSubsystem that tracks a list of actors in a spatial grid and implements an avoidance algorithm
C++:
#include "WorldSubsystem.h"
#include "Components/StaticMeshComponent.h"
#include "Math/UnrealMathUtility.h"
// Forward declare the avoidance algorithm function
FVector Avoid(const AActor& Actor, const TArray<AActor*>& neighbors);
class FAvoidanceSubsystem : public UWorldSubsystem
public:
    // Initializes the subsystem with the given grid size and cell size
    void Initialize(float gridSize, float cellSize)
        GridSize = gridSize;
        CellSize = cellSize;
        NumCells = FMath::CeilToInt(gridSize / cellSize);
        Cells.SetNum(NumCells * NumCells);
    // Adds the given actor to the subsystem's tracking list
    void AddActor(AActor& actor)
        Actors.Add(&actor);
        UpdateActorCell(actor);
    // Removes the given actor from the subsystem's tracking list
    void RemoveActor(AActor& actor)
        Actors.Remove(&actor);
        UpdateActorCell(actor, true);
    // Updates the actor's position in the grid
    void UpdateActor(AActor& actor)
        // Find the actor's neighbors in the grid
        TArray<AActor*> neighbors;
        FindNeighbors(actor, neighbors);
        // Apply the avoidance algorithm to the actor
        FVector avoidance = Avoid(actor, neighbors);
        // Update the actor's velocity based on the avoidance vector
        UStaticMeshComponent* mesh = actor.FindComponentByClass<UStaticMeshComponent>();
        if (mesh)
            mesh->AddImpulse(avoidance);
private:
    // Updates the actor's position in the grid by adding or removing it from the appropriate cell
    void UpdateActorCell(AActor& actor, bool bRemove = false)
        FVector location = actor.GetActorLocation();
        int x = FMath::FloorToInt(location.X / CellSize);
        int y = FMath::FloorToInt(location.Y / CellSize);
        int index = y * NumCells + x;
        if (bRemove)
            Cells[index].Remove(&actor);
        else
            Cells[index].Add(&actor);
    // Finds the actors that are neighbors to the given actor in the grid
    void FindNeighbors(const AActor& actor, TArray<AActor*>& neighbors)
        for (int i = -1; i <= 1; i++)
            for (int j = -1; j <= 1; j++)
                int xIndex = x + i;
                int yIndex = y + j;
                if (xIndex >= 0 && xIndex < NumCells && yIndex >= 0 && yIndex < NumCells)
                    int index = yIndex * NumCells + xIndex;
                    for (AActor* neighbor : Cells[index])
                        if (neighbor != &actor)
                            neighbors.Add(neighbor);
    // The size of the grid
    float GridSize;
    // The size of each cell in the grid
    float CellSize;
    // The number of cells in each row/column of the grid
    int NumCells;
    // The actors being tracked by the subsystem
    // The grid cells, which contain the actors within them
    TArray<TArray<AActor*>> Cells;
// Example implementation of the avoidance algorithm
FVector Avoid(const AActor& actor, const TArray<AActor*>& neighbors)
    FVector avoidance = FVector::ZeroVector;
    for (const AActor* neighbor : neighbors)
        FVector direction = actor.GetActorLocation() - neighbor->GetActorLocation();
        float distance = direction.Size();
        if (distance < 200.0f)
            avoidance += direction.GetSafeNormal() * (200.0f - distance);
    return avoidance;
It's not the most elegant code in the world, or efficient, some sloppy stuff like uninitialised members, but I'd probably progress a junior candidate coming up with that as an interview task.
I gave it a couple of follow up prompts to tidy it up and optimise a bit....ended up with some decent code.
Wild!
Copilot is worth a look too and is more specific to code.
No, and that is an issue, it's predicting text and will give you wrong answers too.
Certainly very useful to help with productivity or for initially taking a look at some way of doing things, could replace searching stack overflow etc.. but definitely exercise some skepticism with the answers.
It's rather clever but it's going to raise a load of issues in academia.
Perhaps more so in the US where things are more coursework-heavy, it's not necessarily writing A-grade essays yet but it could certainly be used to cheat.
The easy solution is to move towards 100% exams and in-class tests etc.. for summative assessments and use coursework for formative assessments only; compulsory to submit and to gain a passing grade in but doesn't affect the final module grade providing that's been fulfilled.
been using it as a more directed search for programming problem. Although not 100% reliable, it's amazing (and scary) how well it works.
Not sure what the landscape will look like in a decade. Perhaps less explicit writing of code and more prompting and reviewing will become the norm.
well yeah i have been using it but results are not perfect but still its scary and mindblowing at the same time.
it has its limit but idk for how long
I find it really good for creating test data e.g. you can paste in a table schema and tell it to create an insert statement to generate x number of rows.
or use it to optimise code, its good that it not only gives you the answer but it also explains it.
Used it to write a few long winded Powershell scripts that I couldn't be bothered to investigate first at any great length, the worked great so I am happy with that as a time saver.
No. It's only useful for beginner stuff and can't do more advanced programming techniques. I actually had to correct it at least twice yesterday when it was trying to use an invalid resource attribute.
