Why are TVs you buy now come with a rubbish picture out of the box, because I can remember the days where you bought a tv and the picture settings were fine and didn't need changing, or Im I just fussy?
No, but with it being the tv in the main sitting room I cant be always changing it between HD and UHD, so I just leave it on the HD on sky q, as there's not much UHD being aired atm.. But I just think its kind of bad if you have a 4k tv and have it setup in 4k, but the non 4k content looking noticably worse then in the non 4k setting.. I wonder when 4k becomes the standard in a few years will the quality of 1080p and lower content improve when tvs are set to 4k,, I noticed this a few years ago bewteen 720p and 1080p, that 1080p didn't look as sharp and good as 720pHave you tried the "IMAX Enhanced" stuff on Disney+ or anything on Apple TV?
I thinks its Samsung AU7100 55 InchWhat model TV is it?
I have a samsung ultra hd tv but most stuff looks sharper and clearer in normal HD, even the sky tv guide doesnt look as sharp in 2160 res, Why?
upscaled instead of native.
Its just annoying that a lot of content on sky q looks better in 1080 than it does in 2160 and that the whole point of the higher resolution, so that stuff looks better not worse.
If you set the Q box to 1080 you can't watch any UHD stuff. It will say you need a UHD TVIs it still the case with the Q box that if only a 1080p output is selected on the q box the user can no longer view/watch sky UHD content.
