- 2 May 2011
- Woking
What is this rug? Got to say man, it doesn't go with the table!
Rug weaving is his next project...What is this rug? Got to say man, it doesn't go with the table!
Table isn't going there, so it's OKWhat is this rug? Got to say man, it doesn't go with the table!
Well, I was kept up until about 3am this morning because I really want rid of this bookcase and I now have a really cool idea for a bookcase, but it's pretty mega... I'll need to design it on paper, then solidworks, then 3d print a test scaled piece to make sure it'll work. It'll be concrete, metal and woodRug weaving is his next project...![]()
Say whaaaat? I did not know this was a thing!! Damn. Ordered some for future jobs!!anti spatter spray
I preferred the IKEA crap TBH
I won't list all of the projects in various states...Well done. I’m impressed that you finish it. I normally give up at about 75%
Yea, I totallllllly thought this half way through. I also then thought I should have one of those saws that does it for you and you can set the angle? Like a mitre saw but for metal? Either way, I think I still need oneJust a suggestion but next time you weld box section, mitre the ends so you don't need blanking caps. Also if you chamfer the edges that are going to be welded so that you are welding in a "V" it saves a lot of grinding to neaten the weld.
Yeah a mitre saw... Just a mitre saw! Mine came with a wood and metal blade.Yea, I totallllllly thought this half way through. I also then thought I should have one of those saws that does it for you and you can set the angle? Like a mitre saw but for metal? Either way, I think I still need oneAnd a table saw... all of the tools!
*adds to the amazon basketYeah a mitre saw... Just a mitre saw! Mine came with a wood and metal blade.
