Dammit - requires SoD![]()
Yeh I found out the hard way...
First you need to install BG1, then BG2 and use the win-64bit-A7-DlcMerger-v1.3 unpacked into the BG1:EE directory that has the SoD.ZIP
Then EET.EXE works! Right ****
I don't own the originals unfortunately, but are you talking about baldur's gate tutu?If you have non-EE versions of BG1 and 2 there's a similar/same mod for them. From memory it worked well but can't seem to find it. I may still have it installed on my old PC, will fire it up later today and see if I can find it.
On quick google, it seems TuTu might not be what I thought it was, but i came across this http://readme.spellholdstudios.net/BGTReadme.htmHmm not sure, name doesn't ring a bell but it could be it.
Your probably talking about the BGT mod if your talking the original games. Baldurs Gate Trilogy , Trilogy because it merged BG1 + BG2 and its expansion.On quick google, it seems TuTu might not be what I thought it was, but i came across this http://readme.spellholdstudios.net/BGTReadme.htm
CD Keys has it for £3.19.Dammit - requires SoD![]()
Edit: Or you can just use the BGT mod (Baldur's Gate Trilogy) to join the two enhanced editions and while ignoring SoD.
Now that BG3 has a release date and the temptation to play it is massive. I decided to give the original ago as BG3 references the previous games and also they are meant to be very good games.
If you enjoyed BG1 / BG2, you may enjoy Pillars of Eternity 2 - Deadfire. It's basically Baldur's Gate but with pirates, wizards n stuff
Started playing it today and what was midnight, is now 2am![]()
Quite a few strategies in BG1 theres probably too many to list so here is few.Spiders are a pain in the ass with that webbed spell that captures everyone, any advice?
