Sous-vide cooking and vacuum sealing
18 Feb 2013
Perth
I'm getting increasingly tempted to scratch a sous-vide itch and add the SousVide Supreme SVS10L to my kitchen, but the vacuum-sealing aspect of sous-vide cooking is the main concern I have about such a device being a useful addition and not a gadget on par with that sodding panini toaster I've got languishing at the back of one of my kitchen cupboards.
The thing is, what I don't want is a vacuum sealer with single-use bags as I've got a feeling the expense will quickly start to mount up. And I'm also not so sure about the sensitivity of the products aimed at the home market - the commercial-grade ones are very good at keeping delicate foods from getting squished when the air is extracted.
I've seen various reviews of the SVS10L that mention the Reynolds Handi Vac as a suitable alternative to a food-sealer (specifically mentioning the resealable nature of the bags as an advantage) but as far as I can tell, it's not available in the UK and the alternatives we do get are a bit rubbish.
But having just seen this thing on the Lakeland website, I'm tempted to give it a go. The bags seem sturdy and reusable, and being a hand-operated pump it ought to be easy enough to be careful with what you're up to.
Now, I appreciate that there will be very few people stupid enough to go to the expense of owning a sous-vide system, but do any of you have experiences with vacuum sealing systems and can offer some opinions?
I genuinely wouldn't bother getting an expensive vacuum sealer for a home kitchen. I've just got a crappy Andrew James thing and it does the job perfectly well. Obviously you don't want a piece of crap that's going to last a couple of months, but don't get anything professional standard.
I've got a roll of bags that you cut to length and seal at one end before filling so you can make the bags as big or small as you want.
Not just good for sous vide, but plenty other uses such as fermenting, storage etc.
\edit: Lol, just realised this was a thread resurrection!
5 Mar 2009
Essex
Ha, happened on this thread by chance, ordered the nano red, exactly the same as the nano only with a bit of red branding and Anova make a donation to charity, £68 all in, bargain.
D3K
D3K
13 Nov 2014
Gdamnit, can't resist 15 off... cancelling with them needs to be an email that gets a reply within 72hrs :(
17 Jan 2006
Having just dug my sous vide wand out of the cupboard to cook a nice big lump of brisket, I was wondering about reusable bags for the sous vide as I'd like to be able to move away from the single use vacuum bags I currently use - partially for being more ecologically minded but mainly as it I think it would encourage me to use the sous vide more often. I've done a bit of reading up seen a few options but wondered if anyone has any experience or recommendations of any reusable bags?
17 Jan 2006
I've seen silicon ones which I could imagine would be ok to clean but yes plastic ones I can see could be a pain to clean. I might just take a punt on some reasonably cheap ones and see how I get on.
20 Jul 2017
upgraded from a polycarbonate Sous Vide tank and Inkbird circulator to the full chamber sealer and Burton Sous Vide. I would never go back. sear joints after or blowtorch.
