- 25 Mar 2004
- Fareham
Dishwasher your rack*
* dont do this if your female that rack is different![]()
Haha I did try it but it doesn't work fully, I still had to manually clean it!
).AC was where the majority of my usage went last summer, was on from basically 1st July through to end of AugustI'm going to see how this summer goes and may consider getting another battery if it's a sensible thing to do.
Or get some AC installed - not that it really gets hot enough (we're a lizard family).
Some of the generation curves would be interesting to see as obviously mine is very much starts slowly, hits a big peak and then tails off, where as you will get multiple peaks in the day I'm assuming.I'd love a full year of stats because peak generation per month is an interesting metric, as it should roughly follow a curve.
Here's mine so far (rounded down, so actual may be in that kWh somewhere):
September: 21 kWh
October: 18 kWH
November: 11 kWH
December: 8 kWh
January: 9 kWh
It's easy to see that in the peak of summer the generation on my end is likely to be in the 30 kWh range, maybe even into the 40's on some days. Temp will reduce efficiency though.
I just find it hard to justify as it just doesn't get hot enough (for us) - though it's something to think about.
September: 21 kWh
October: 18 kWH
November: 11 kWH
December: 8 kWh
January: 9 kWh
Can also see the shading coming in after October, the impact to the west facing panels is high.
Don't forget can use it for heating too, which I'll be utilising more once my fixed rate tarriff runs out and I can use my batteries at cheap rate.
Producing at 2.6kw and battery is 100%
Currently the diverter is getting its first proper workout heating the water tank![]()
Mines great, spot the shading.
July 43.08
Aug 40.65
Sep 28.43
Oct 21.75
Nov 7.87
We're punching similar numbers on PVO. This is me from last year. I'd expect you to generate a little more over the summer months.
how big is your system again??Some of the generation curves would be interesting to see as obviously mine is very much starts slowly, hits a big peak and then tails off, where as you will get multiple peaks in the day I'm assuming.
July 43.08
Aug 40.65
Sep 28.43
Oct 21.75
Nov 7.87
Dec and January don't count as I only had it for 5 days in each month.
The extra battery charge bit this morning isn't helping things, I've also been hitting capacity!
Washing machine on, usually the battery would have more headroom to charge into.
6.3kwhhow big is your system again??
6.3kwh
do you get lots of shading during sunny days??6.3kwh
