Can I use a m.2 Nvme gen4 on a gen3 motherboard ?
29 Dec 2012
I was wondering if I could use Nvme gen4 on a gen 3 board ?
I think my board (Asus crosshair VI) only has one slot, so I may want to upgrade but just want to make sure I don't get the wrong one, but I still want to make sure I get the best option for the money and have some future flexibility.
They might say in the datasheet, or you can check the controller, the SN570 and SN770 both say that they're backwards compatible. There are some drives that don't like earlier PCI-E gen, or can't operate with 2 lanes.
Will it say in the specification or product description or would I need to have a detailed look at each ?
Sometimes, if you can't find out try google, e.g. "SN770 PCI-E 3.0" and if it doesn't work you're likely to get posts like "my SSD doesn't work" :D
