Password managers
Unfortunately it doesnt have a clean and quick way to manage multiple logins from the page that I can see.
Which is annoying as so far everything else is spot on! But its an essential feature/ability I need.
One of the things that seems "missing" from bitwarden over others is it doesnt have an autofill detection on login boxes? I have to either right click or open the browser extension icon, or is this an option to turn on?
IIRC it's done this way deliberately as an extra layer of security to prevent hijacking of passwords that are auto-filled into a page. I think it does have an option to enable the auto fill though.
No good to me then, as an example for one particular site in my work I have 4 different logins from the same page, that then goes to a new page on each with another 2-3 logins depending on what is being done.
The ability to just click the login box and select the right account quickly when swapping between them is critical. As stupid as it sounds, that extra "right click, find the right context menu, move mouse, select account" over "click box, click account" isnt acceptable :(
Right but then use autofill and you don't have to right click any menu. You have to turn this on.
Bitwarden supports extra vaults (Companies) so you can have 1 log in with different vaults. i.e Work/Home etc.
Yes I have autofill turned on, and if I have to use a different login to the one it autofills its an absolute chore compared to Lastpass for example.
Why is it an issue?
Productivity. When im having to log in and out of multiple levels of systems and subsystems rapidly multiple times within an hour with multiple differing logins, the extra faff of bitwarden over basically every other password managers implementation is an issue.
Then you don't want bitwarden, have you tested each one of them to see which one increases productivity then?
Is that multiple accounts on a unique url? I'm curious how lastpass deal with that. IIRC it still had a pop-up box to select the account that you wish to log into?
I can't see how you'd avoid that as you'd have multiple accounts all referencing the same url, so it would still require you to manually select one?
Yes, but on everything else you left click the password box and chose the account, 2 clicks and takes half a second.
The Bitwarden implementation is very poor in this regard imho.
If they added this in then I would use it 100%.
I do it with two clicks at the minute. Given I'm already at the login page, I click the Bitwarden extension icon on Chrome and then click the login I would like it to use to login with. Is that not what you mean?
No what he's after is when he clicks the password box with lastpass it pops up with a list of saved accounts, you select one and it auto-fills.
As opposed to Bitwarden you'd have to click the Bitwarden icon and then select the account for auto-fill. It's not much difference or any extra steps, it's just a behavioral change that would be required.
I had wondered if it was something LastPass might have copyrighted.
Then click then
Why do you think I was asking if I had missed an option?
Well, I don't know if it's considered more work... click the login box, select an account or move mouse up to bitwarden icon, click and click an account. Same clicks, but maybe 1 second longer?
