Hi, after playing a bit with my 8600k I've managed to reach the 5GHz mark keeping temps and voltage within safe values (around 80ºC and below 1.350v), however, I suffer from a huge thermal throttling that downclocks the cpu close to 3.6GHz. I am including here the results of HWinfo64 at the 15 min mark while running Prime95 small FFT (https://imgur.com/RXVkjvN). You can see that the cpu doesn't keep up with stable 5 GHz with my current config: all core cpu ratio 50, cpu cache ratio 45, PL1 120, PL2 150, offset 140mv and LLC2. I believe the reason are the power limits I've set, lowering the clock (yellow highlighting) when too much power is withdrawn.
An idea to solve this throttling, was to rise the cpu thermal throttle temperature to a max of 90ºC, and then setting the new PL1 with the value of power used at that temp. However, I cannot find that setting in my BIOS. Here are the options I'm able to modify and my current config: https://imgur.com/fTzOReh
Can someone please help telling me if my approach is correct / I am able to do it / how to do it? Thanks a lot!!!!
PC: i5-8600k, Asrock z370 Extreme 4, 2x16gb ddr4 Crucial Ballistix 3600 CL16, PSU Corsair RM650x, Noctua nh-d14, 2xSamsung Evo 850 500gb ssd, case Corsair c70.
!! Yesterday, I was observing that my voltage was going up to 1.37/1.38v while gaming with the previous stable settings I had (exactly the same ones I linked in my OP, with max Prime95 vcore under load of 1.344v and max temp under load of 79/81ºC). I had those settings saved in one of my bios saved profiles and, basically, I've been reverting to that profile each time I wasn't happy with the changes I was doing along the way. Well, after reading about cases in which the new bios settings were not being updated properly (I thought that was happening as the voltages were rising over the stablished max with Prime95), I decided to select LOAD BIOS DEFAULTS and restart the PC with the idea of setting the profile from zero and saving it again. Something as simple as that, but now... well..., now I have no splash screen whatsoever, no windows booting,... nothing.
