Synology NAS Drive Compatability
21 Mar 2004
Dorset
I’m about to order a DS220+ and a couple of Seagate Ironwolf 4tb hardrives. Trouble is when you look at the Synology compatibility website only two Ironwolf drives are fully compatible the ST4000VN008 2DR166 and ST4000VN006 3CW104. This limits where I can buy drives. Is the Synology NAS really that fussy about the drives? I contacted Synology support and they work off a script and refer me to the compatibility webpage.
I have a DS220+. From my experience the drives will be fine, Synology just like to upsell, everything. Try them. It is a great NAS
Thanks. Do you mean any 4tb drive will be fine? I‘m sure the two I’ve mentioned will be but I wondered if anybody had successfully put in drives not on the compatability list.
Oh and are you happy with your 220+?
I expect the 4tb Ironwolf drives to be fine, amazed if they are not.
Yes I love it. it is a bit 'set up and forget' but that is how it should be. I run HA in a docker, Plex and backup my OneDrive to it, whilst mirroring to another offsite.
The Synology NAS will complain if you try to create an array with unsupported drives but will likely let you continue at your own risk. I know this from personal experience as when I bought a NAS a couple of years ago I fell into the noob trap of buying 4 SMR drives as they were cheaper but also because they happened to be recommended by the guy who runs the "NAS Compares" youtube channel as a goof black friday deal, but failed to mention the potential drawbacks of SMR drives. You'd have thought that guy would have pointed this out, but for some reason he forgot. Being none the wiser I got them and set the thing up with them and got the warning whilst creating the array, but continued and let it set up.
It has been fine since, and reading up about SMR drives I know that my use case is on the lower end of the potential risks because I don't to a lot of daily writing, and I also have external back ups of everything. The main drawback apparently is is it ever came to the NAS rebuilding the array of one drive fails, it take much much longer to complete apparently. Anyway, I am actually now planning on replacing them with CMR drives, mostly because I am running out of space, and the drives taken out will become mre external back up.
In summary, yes I have put "non-compatible" drives in a Synology NAS, but I kind of wish I hadn't but also know that because I keep backups it's not such a big deal.
Thanks for everyone’s input. I contacted Synology support again with a specific question about different spin speeds using the compatible drives in my first post and they said not an issue.
