Loved the F1s on previous cars, shame they don’t make my current size.
I had the AS3 before the PS4, I thought the AS3 was okay, not as quiet as the PS4 and wear out about the same from memory.
I do believe Raymond has the T5which engine does the c30 have? the 230hp T5 or the 100hp 1.6L?
ah ok, makes sense to get some better performing tyres thenI do believe Raymond has the T5![]()
My only criticism of PS4s is they are no good below a certain temperature, like 4c maybe, but then this is the same for more or less every tyre, but it feels like they get a bit worse.
205/50/17
You need to watch for rubbing if you go up a size. It’s only 205s on the Cooper S and JCW Mini’s, if you go up to 215 or 225s you can get tyre rubbing depending on the brand.
That is a bit of a small width for something with 220+HP. What is the width of your rims? As if you can get 225/45/17 to fit you will find they are a lot cheaper with a lot more choice and also virtually the same so your speedo will still be good. I just paid last week £90 a tyre full fitted for AS6 fitted at F1 autocentres as they had a promo on.
I don’t know the answer but it’s called “VOLVO V50 S40 C30 17 INCH CRATUS ALLOY”
2010 Mk1 Volvo C30 FL 17" Alloy Wheel 31290177 for sale online | eBay
Find many great new & used options and get the best deals for 2010 Mk1 Volvo C30 FL 17" Alloy Wheel 31290177 at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
205 is the size recommended when I put the plate into search.
4 fitted Efficency Performance is £423, 4 AS6 is £560.
p.s. the nearest garage that is on F1autocentre is 50miles round trip away.
do price matching on your nearest shop, used to drive 30miles for tyres , last ones at national just a couple of miles, saving > gallon, F1 had done price match and Halfords;Going direct to companies gives you a cheaper price.
they're fine had them forever on 3series - better wet grip than michelins in the same segment, but shorter life, bridgestone potenza I had before also good grip but shorter life;
I'd like to try cross-climates shi mentioned next time, for frequently muddy local roads, frost, rwd.
