Octopus gave me a call earlier to provide a quote on solar installation. 5 panels with battery prices.
2.6kWh £8800
5.2kWh £9500
9.5kWh £11700
South West facing roof and London location so good levels of Sun through the year. I’m using about 12 kW a day. Any idea what the payback is?
Definitely not worth it for 5 panels.Octopus gave me a call earlier to provide a quote on solar installation. 5 panels with battery prices.
2.6kWh £8800
5.2kWh £9500
9.5kWh £11700
and then jumped from 79% to 100% just now, so have whacked on the pyrolytic oven to burn some electrons rather than exporting!Mine do it as well when very low. My SOC minimum is 10%, but when sitting at 10% for hours when its cold they will suddenly drop as low as 5%. At 5% they trickle charge back to 10%.
I think its just the chemistry. They maybe have say 10% at 15 degrees but when they drop to say 10 degrees they lose the ability to provide the same power.
From what i can tell the management systems work off current and as such extrapolate charge level rather than it being an exact thing.
I think I could squeeze up to 8, the panels are 1.7x1.1m. What would you expect the price for this to be? Assuming the largest battery? I’ll likely top it up on the overnight cheap rates.£12.7K for 9.5kWh battery with 18 panels just quoted in the last page or two:
Solar panels and battery - any real world recommendations?
Strange thing about my eco7 SMET2 meter is you can still hear it click at 00.30 and again at 7.30 like there is a physical switch being switched on/offforums.overclockers.co.uk
That is an extra £1K for another 13 panels, which makes that price from Octopus look non-competitive.
5 panels is a very low number to install though, at 400W you'd only have a 2kW system. Can't add more?
My concern also. Payback is going to be 10 years I guess which is very long.Definitely not worth it for 5 panels.
Octopus Flux | Energy Tariff Designed for Solar & Batteries | Octopus Energy
Octopus Flux lets you sell your excess solar power using manual battery control. You’re in charge of when to import or export.octopus.energy
Ooooh, this looks really good.![]()
So out in 2 years...Has anyone seen Givenergy has a new battery coming? All in one 13.5k/w which for us is the perfect size. Hopefully out in the next month or so. Full UPS built within too.
I’m looking at combining it with a circa 6kw solar set up.
Its basically a Tesla power wall competitor. From what I understand it is AC coupled so you'll need a separate inverter for your solar.Has anyone seen Givenergy has a new battery coming? All in one 13.5k/w which for us is the perfect size. Hopefully out in the next month or so. Full UPS built within too.
I guess it depends on how many batteries you have? One 5kWh battery should charge in 3 hours right?My gut feeling is that in winter 3 hours isn't long enough, really need minimum of 4 like on Go for the battery charge.
Could live with the rest though.
