Thought the point of SMETS1/SMETS2 is they can do 30 min data reads, don't need see the need for Eco 7 variants. I'm on Go which kind of acts like Eco 7 and Octopus have no issue with it being a SMETS1 meter.
Strange thing about my eco7 SMET2 meter is you can still hear it click at 00.30 and again at 7.30 like there is a physical switch being switched on/off
Thats good, I got through until mid October before taking anything from the grid. Although with the wifes car that will change somewhat now. Like you say it's all about balancing it and working out if you can charge cheap overnight when you need to, will the extra you get for import offset those losses. I'd be happy for April to September being 90% off grid (could easily be 100 without the car) Just about seeing what is available in a few months time as it's always changing.Using September as my sample month from last year, as it's likely less than say June or July would be, but is a good indicator of how life without Octopus Go might be.
Consumption for the month just over 500 kWh
Solar generation 375 kWh (75%):
162 kWh from the grid, though a lot is off-peak:
Exported 31 kWh:
According to my Octopus bill (data from website only goes back 4 months) I used:
123 kWh off-peak
15.4 kWh on-peak
For 01/09 - 26/09.
Based on all of this, I would say that in September, I'd still be taking some units from the grid, at least the delta between generation and usage. It would be 125 kWh here. A decent tariff like Agile with opportunity for low rates at times would allow me to force charge during the cheapest times of day, and a good export price means I could potentially not worry about over-filling if the import rates are good enough.
I don't expect to really be making anything from export though in September.
I guess in the prior 3-4 months I'd likely be exporting more, and using very little from the grid.
I'd want to switch back to a cheaper ToU tariff like Go by sometime in October probably (300 kWh last October generation) or the delta will slip too far the other way.
Hello,
We're in the process of obtaining quotes, and was wonder if those more in the know would be able to cast their eye over this:
It's the first quote we've had, so would be good to use it as a baseline if it's a reasonable figure. They've recommended Optimisers at £40/panel on top of that figure also.
Thanks in advance.![]()
Good to know, the guys came recommended and are local too which is a bonus.Looks like a good quote tbh.
Quote looks decent compared to a lot I've seen lately.
I paid £8.5K for 13 * 370W panels, GE Hybrid and 8.2kWh battery about half a year ago but prices have moved on since then.
Base costs seem up for all quotes, alongside your system having more panels and a bigger/newer battery and probably inverter (check it's Gen 2).
What is your usage like in reality per day?
According to EDF we consumed 2477Kw/h between 27/7/22 - 9/1/23. So say 5 1/2 months for argument's sake, 167 days = 14.8Kw/h day?
Sounds like a decent sized system then, probably over-produce a bit in Summer but panels are cheap, and more panels is always good, gives you more options. Winter will also generate a bit more which is when you need it most.
See if you can check the specifics about the optimiser requirements and what the difference might be with or without them, and as per MKW post bird protection is worth adding as well.
This was my old one. I reckon original from 70 years go when the house was built. The clock on the left would switch between the two rates in the meter - made a bit of a click as it happened.
Now it's a Kaifa MA120B - soooo much tidier and easier.
Noted, will do. I've just mailed them about that and the solar diverter too. That's definitely something I'd want to take advantage of. Thanks!
If thats really your usage, with that battery if you have it programmable to top up from the grid, get on the cheapest E7 tariff you can find (I think its UW atm?) top up over the night and use it to fill in the blanks in the day when the sun isnt shining enough and youre going to be having a very cheap bill.
Good call, I shall look into that as well. The prospect of getting shot of EDF is also very appealing.
