Caporegime
- 18 Oct 2002
Lol, you daft **** definitely not running it now.
lol yes but it's just curiosity
So I tried to OC a bit, Gave it PL 15% and some core tuning and about 5% off the voltage.
Tried it in a couple of games and seems stable... any specific games that can stress an OC on the 7900xtx (Red Devil)?
Had a similar TS score to that with the XTX I tried and got 140fps 4k/Ultra settings.Be interested to see what frames you are getting in Warzone.
The best stress test is usually gaming sadly, but Port Royal and Firestrike Ultra stress tests are decent.I take it the time spy extreme is better than the standard stress test to test for stability?
port Royal extreme or standardThe best stress test is usually gaming sadly, but Port Royal and Firestrike stress tests are decent.
Is there a Port Royal Extreme? I didn't realise, try both I guess.port Royal extreme or standard
I have just checked, no there isn’tIs there a Port Royal Extreme? I didn't realise, try both I guess.
Funny feeling your CPU is bottlenecking you. Have you tried a run rendering at 4k to see what kind of FPS you get?I’m not getting much higher than that on 1440p mainly low settings fidelity fxcas at 60. That’s without an overclock on the card. GPU hangs around 75/85% usage.
My timespy score was 30,125 GPU 13,885 CPU. 25,628 both.
Timespy extreme was 14,977 GPU 6248 CPU 12,382 both.
Definitely. You'll need at least a 5800X3D to see anywhere near the potential of an XTX. Ideally, you'd pair it with a Ryzen 7000 series CPU minimum.I've got a
I've got a
@henry hoov3r one other thing I know that warzone on Intel systems loves fast ram. Whilst 3600mhz is sweet spot on amd I think on your Intel platform you could go a lot higher.
He's got a superiority complex but check out some older videos by the frame chasers guy on YouTube. Should shed some light on it.
