- 23 Dec 2022
- London
What's your CPU running at? Have you oc'd it at all??
I just enabled game boost in the bios. It was hitting 5ghz in the timespy test.
Will install it and check it out. Mainly gaming on 1440p though.Be interested to see what frames you are getting in Warzone.
EDIT:
Overlay pic, Basically full graphics no FSR. PL15%, Min Frequency 2400mhz, Max 2900mhz, 1130mv.
I've got a
Funny feeling your CPU is bottlenecking you. Have you tried a run rendering at 4k to see what kind of FPS you get?
This was the video I was thinking about -Tried that and was getting 180/200 fps and GPU utilization was at 100% so I guess I know what’s next on the shopping list!
Unfortunately eaten up by the power hungry 7900xtx in this instanceAnd 5800x3d with all core -30 PBO off set saves even more juice.
Yes, You are leaving performance on the table with anything less than an X3D chip even at 4K.WOuld there be any point in me grabbing a 5800X3D - Currently on an 5800X standard, but obviously have my 7900XTX - I game mainly on my 4k TV downstairs so not sure there would be much point for the cost at that resolution?
Bums, may as well just wait for the 7xxxX3D then and go the whole hog!Yes, You are leaving performance on the table with anything less than an X3D chip even at 4K.
Better idea for more performance if you have the funds tbh.Bums, may as well just wait for the 7xxxX3D then and go the whole hog!
At 4k it's unlikelyt unless you are experiencing frame drops on the lows - its a much less CPU bound resolution so I would do some benchmarking first before spending any cash.WOuld there be any point in me grabbing a 5800X3D - Currently on an 5800X standard, but obviously have my 7900XTX - I game mainly on my 4k TV downstairs so not sure there would be much point for the cost at that resolution?
I'm running a 5900X.I was waiting for the 7800x3D but had a gut feeling it was going to be delayed and just smacked the 5800x3D (Had a 5900x) as a sidegrade as much.... I was wrong.
I was completely and utterly wrong. The 5800x3D is a gaming monster. Usually a CPU from a brand is good in some things and bad in others.
This low TDP guy is a monster in everything I throw at it.
Factorio type games? Best in Class.
3D games? Minimum Frames that are deliciously smooth.
General daily workloads? No major difference from the 5900x.
Best bang for buck for a gamer now is a decent B550 or X570 mobo with some decent DDR4 3600mhz-CL16 or CL14 Ram (Get the cheapest, Less than 1% difference on the 5800x3D) and you will be set for 3 years. By then DDR5 should have matured enough and mobo prices should have normlized.
Oh yah, The 5800x3D is cooled by a Deepcool AK620. It's that good.
