NHBC advise flashings “should be tucked 25mm into a brick joint and wedged in place at not more than 450mm centres, or a minimum of one per step for stepped flashings”
(I realise that is not a stepped flashing but the principle is the same and arguably more important to have it detailed into the masonry)
nhbc-standards.co.uk
Just checked the lead association, they say the same (most likely where the NHBC guidance came from)
Login - NHBC Standards 2025
Access to NHBC Standards is limited to our registered builders/developers, their professional partners and NHBC policyholders. Please register or log in to access the Standards and Technical Guidance Notes. Don’t have an account? Register The NHBC Standards are produced by NHBC as guidance...
