Ah that's interesting, i wonder if there's any bigger oil pan mods like you can get one Subaru's to increase the oil volume and add baffles.
BMW 130i
Moroso do that's roughly 1l more capacity, plus baffles and extra ports if necessary (e.g. turboing), I've not really heard of many people in Celicas having issues with that and mine has survived on trackday at Castle Combe fine but that's hardly a full validation
I believe some people fit/use the 1zz oil pan thinking it's an upgrade but pretty sure that's false and it's no better than the 2zz one.
MR2 fitment shouldn't be too different, at least I believe the orientation of the engine is the same due to the MR layout...
NASCAR it is!Yea that's a mod people do on the 2zz Elise as well. The 1zz pan does have a baffle in it, but I don't think it's as simple as it sounds. There is a reason Toyota didn't use it themselves but can't remember what it is.
It's high G right turns which kills them apparently. If you can avoid that you might be ok![]()
So one of my aims this year is to get on the track a bit more. I'm after something no frills that is fun to drive and reliable, a manual RWD would ideally be what I'm after but not essential. Doesn't need to be in good cosmetic condition but will need to be road legal so I can drive there and back. I can do the odd bit off maintenance too but don't want to be rebuilding engines or gearboxes.. A few I've been looking at;
Anyone have any recommendations or track experience on the above? I've only driven a handful of these and none on a track.
- MX5 - the classic choice
- RX8 - Maybe not as reliable as I'd like
- 350Z - Possibly a bit over budget
- Z4 - not looked too much into this but seems like it should work
- EP3 Type R - I think this would be a decent FWD option
- Golf GTI - same but hard to get a manual one in NZ
- Audi TT Quattro - not sure how fun it would be
Happy to hear thoughts!
NASCAR it is!
