I would really appreciate if anyone who owns a 4070 Ti, 4080, or 4090 could help with the following test (below). This discussion started on the NFC discord, and the intention is to see how much power we could pack into a tiny case (the Skyreach 4 Mini, specifically, at 5.5L). I own 2 of these cases, and the last GPU I had installed was the EVGA XC 3060 Ti, which just fits given the 2 slot and 215mm constraints.
With the 40s series being a bit underwhelming from the pricing perspective, and the huge coolers that seem to come with even modest cards, I just ignored it. But then someone started pushing the idea of a custom cooler on a heavily power limited and undervolted RTX 4090 fitting in the above case.
So here is the added spiciness for this: powering from 2 x HDPlex 250 watt GaN units (they can be daisy-chained, with one powering the GPU, and the other powering the motherboard, CPU, etc.). So a total headroom of 250w + whatever the PCIE slot provides. The HDPlex can handle some spikes before tripping, but ideally you wouldn't want to regularly throw more than 250w average, and 300w with spikes at it to keep it stable.
So the request is: if you own a 40 series card, could you please use MSI Afterburner to provide 2 sets of results (FPS and GPU Power Usage) using Kombustor with the "BENCHMARK: preset 1440"?
1) At stock
2) Undervolted and power limited to get a power draw as close to 250w for the GPU as possible (if you could post your voltage curve that would be great).
The intention is to work out if the 4070 Ti, or the 4080, or the 4090 are materially different in FPS at such a constrained power point - before we investigate spending lots of money and time making a custom cooler to handle the 250w of heat output (which in theory the case can handle - it was used with the mini 1080 Ti by many people in the past).
I appreciate this is niche, and also time consuming, but if you could help it would be greatly appreciated.
Many thanks,
Hewligan
1) At stock
Many thanks,
Hewligan
