Except its clearly showing in 4k and 1440p reviews that the cpu has a massive bearing on the performance. My 9980xe is holding back my 4090 a lot.
up 50% difference in framerates at 1440p between a 13700 and a 5800x and up to 57% at 4k.
Except? I can't tell if you're disagreeing with me?
Clearly the video proves my point, the 13700K is 2 generations newer and higher end, it is a faster CPU, obviously.
If you were to look at the 4K results you would say there isn't much difference, 8%.
The 1080P results prove there is a much greater difference than that, 23%.
So 1080P testing matters.
