Fair enough but what is the 330w test you mentioned that a PA120 fails at but a U12A passes? I find it highly unlikely given that the PA120 easily beats the U12A at 120w, 165w and 260w.Exactly, cause im running benchmarks. For everything else a 30€ off the shelf cooler is enough,, you don't need huge dual tower coolers.
And they are not near as expensive as NH-D15 and similar stupidly high priced coolers. Ones I use are almost all less than 50€
