That's like comparing a laptop with a desktopWhile competitive with most twin towers it doesn't beat them.
NH-U12A prices of £109.99 and £124.99 are among the highest cooler prices out there.
As for quality, there are many other coolers just as well made.
Again, only thing Noctua has others don't is free mount updates, but I'm not paying half again to twice as much for a cooler just to be able to get mount update in 3-5 years. I'll save £55.00-80.00 for other things and in 3-5 years buy a new cooler for £40-60. Then sell old system as complete working unit to offset some of expense.![]()
The laptop that performs similarly to a desktop will be more expensive - but still a sign of better engineering. There is no other single tower cooler that gets anywhere near the U12A, that's freaking impressive.
Regarding quality, have you actually had it side by side with a cheaper cooler to compare build quality? Cause I have compared it with several air coolers and the U12A feels much much higher quality.
Of course if you are on a budget you don't go for the U12A, but the same way if you are on a budget you don't go for an sff pc. Bulkier pcs tend to cost less for similar performance.
