Samsung 960 EVO upgrade
22 Nov 2017
Afternoon all.
My SSD is starting to fill up and so I am thinking of upgrading to a newer drive, probably 500GB or 1TB. My current drive is a Samsung 960 EVO NVMe any recommendations for a similar or better drive in terms of speed and reliability. Also any recommendations for a PCIE card to put my existing drive into and potentially use for my documents?
Many thanks
Darren
You mean pcie to USB, or pcie internal to plug into motherboard?
Sorry I should have been clearer. I only have one NVME slot on the motherboard so I thought (perhaps wrongly) that I could get a PCIE card with an NVME slot on it and I could use that with my existing NVME when I replace the drive for a larger drive.
Which motherboard do you have?
Your going to be limited to pcie 2 4x in the second x16 slot but you can buy cards for £10-20 quid, SilverStone ECM25 should work. overclockers dont seem to sell pcie-nvme cards so check elsewhere.
