Yes, if you want some extra performance.Sorry if this is a stupid question but is that beneficial on stock power settings?
It managed benching with that number just fine. It's just there's a few games and apps that fall over with that setting, so I've dialed it back to to 2650Mhz so everything I use and play is fully stable.Try 2714Mhz fast timing.
If you've reduced voltage a lot, you might need a little bump for it to be stable.It managed benching with that number just fine. It's just there's a few games and apps that fall over with that setting, so I've dialed it back to to 2650Mhz so everything I use and play is fully stable.
You are unlikely to get any extra performance from the card by putting it under a waterblock. If you want a quieter system it can help but if your card currently does not have coil whine it may develop it once you change the cooler , it is always a risk. The only real reason to watercool a gpu these days is for aestetic reasons. I love my watercooled system but it cost a fortune and performs no better than if I had left the air cooled components on.
We have very very similar systems so easy to compare and contrast, my card is a Sapphire MBA. Some of my numbers are , 14500 Timespy extreme gpu score when on stock settings and around max 16200 when undervolted, memory speed and power limits increased. When on stock settings the temps are ludicrously low with the hotspot around 65 and when overclocked the hotspot is around 80
Had some time today, so tried to see what could be done by adding some volts back in.If you've reduced voltage a lot, you might need a little bump for it to be stable.
There is a bit of a difference between GPU and junction. Your fan curve is rather flat at 50%. Mine usually stays between 5 and 10 degrees difference.What's everyone hotspot temps with the nitro+? My new one seems a bit toastier than my last. GPU temps are okay, but junction seems higher? This one even UVs better.
It kinda depends on if your motherboard has a reinforced PCIe x16 slot (some do, most don't). If reinforced, you can probably get away with not fitting the bracket in for the mean time. If it's not, you probably do want an anti-sag item in there somewhere to prevent the GPU from bending and potentially snapping the PCIe slot from it's contacts. Also beware, that the bracket that's provided with the Nitro+ as @eeii has said it fairly sizeable, and some users have repoted being unable to utilise it because their cases PCI slot screws were not long enough to accomodate it.Finally got around to installing the nitro+ in my pc, only needed to remove the middle front case fan so have 2 fans(top & bottom). I’ve not installed the anti-sag bracket so will there be any issues? I’m building a new pc in the lian li o11d or the air mini in the coming weeks/months once the 7800x3d releases so it wouldn’t be in this pc for too long, will it cause any damage to the motherboard/card pci-e in that period?
When I got my replacement nitro, it came with longer screws! My first one definitely didn't have them. Made installing the bracket a million times easier.It kinda depends on if your motherboard has a reinforced PCIe x16 slot (some do, most don't). If reinforced, you can probably get away with not fitting the bracket in for the mean time. If it's not, you probably do want an anti-sag item in there somewhere to prevent the GPU from bending and potentially snapping the PCIe slot from it's contacts. Also beware, that the bracket that's provided with the Nitro+ as @eeii has said it fairly sizeable, and some users have repoted being unable to utilise it because their cases PCI slot screws were not long enough to accomodate it.
That’s a shame is it definitely the card. It could be the power supply. Might be worth checking with a kitchen roll.Yep still coil whine so I will keep this one no point trying to change it again as it will probably be the same thing again.
I will try and find a GPU-intensive game to push it to the limits to see if that, over time reduces the coil whine.
But another than the coil whine, the TUF is a beautiful and well-built card. Runs my LG C2 beautifully.
