- 11 Aug 2017
I've run a few tests and I've encountered a problem since installing my second hand GTX 3080.
All of the benchmark tests I ran were fine and showed good results. All apart from the 3d Mark demo test. About 3 minutes in, my PC hard resets. No BSOD, just a reset.
I tried running a few games and they all run fine. Until I ran Darktide on max settings. 5 minutes into a game and my PC hard resets.
All temperature states look absolutely fine. I suspect it's the PSU. Also, the drivers are all up to date and everything else worked before I put the new card in.
MOBO: B350 Carbon
CPU: Ryzen 7 5800x
RAM: 32 GB DDR4
PSU: CORSAIR 750
GPU: GTX 3080 10gb
Any thoughts?
MOBO: B350 Carbon
CPU: Ryzen 7 5800x
RAM: 32 GB DDR4
PSU: CORSAIR 750
GPU: GTX 3080 10gb
Any thoughts?
mine was an 850W Seasonic Gold, but from 2013 (my mate with the same psu had the same issue), newer PSU's are a lot better in regards to this though so if it's new it may not be the case!
