Permabanned
- 9 Aug 2008
It's due to the ultra long location, it ruins the formatting
Location should be turned off. Not really relevant IMO.
Never seen this happen before. On desktop.
1) Gah, feel a bit dumb as I'd tried everything, but TBF that icon is pretty remarkably discreet1) You’re out of the fancy editor. Tap the three dots at the top right of the reply box and make sure the square brackets below are black.
2) Dunno
Sorted.
I just added "Apparently I have to add enough words here so there we are, maybe it will work now" but thought I'd try just the original comment first. It worked!Feedback working fine for me. Maybe try a longer comment? Something tells me there was a minimum amount of characters required, but I could be wrong.
Weird issue for me that's making the forum unusable. The majority of times I go into threads in SC, Chrome on my phone freezes and then the app will completely crash. I have to close Chrome and hope it will give me enough time to back out of the thread. The problem is getting worse.
That one I can't think is down to the forum, as if it was it would affect all threads in all parts of the forum (there is literally nothing different about SC as far as the browser is concerned in regards to how the forum operates).Weird issue for me that's making the forum unusable. The majority of times I go into threads in SC, Chrome on my phone freezes and then the app will completely crash. I have to close Chrome and hope it will give me enough time to back out of the thread. The problem is getting worse.
Forums can't crash unless you're serving them.I've never had the forum crash once ever.
