I have X670 Aorus Elite, and most of the time when I restart the PC. Say after a driver update or you have just turned it off and forgot to do something and need to turn it back on it just hangs when it's doing the bios checks and go's no further. I originally thought it was doing the memory checks, but it just stops and does nothing else. I have even left it for an hour after the problem occurred, to see if it was the system doing the memory check and it did nothing. I have used 2 different memory kits on it, G.Skill Trident z5 6000 cl32 expo and Kingston Fury Beast 6000 cl40 which are on the motherboard QVL and they both have the same problem. Even reinstalled windows and used a different graphics card and the problem still happens. Update the bios multiple times and it is currently on the latest bios, reset the bios to the stock optimal settings and still the fault happens.
Also if I turn the PC off for say 20 minutes after having this problem, then turn it back on it boots up fine.
Anyone have any ideas?
If not I'm going to look into RMA with the supplier.
