- 21 Oct 2011
- ST4
For take-off, yes. But what does that have to with landing on Mars?It is not 33 engines on Mars, but just 6 from Starship.
Are you being deliberatly obtuse?The booster doesn't land on Mars.
Only the upper Starship does with six engines. The big booster only gets the Starship up to space.
As long as you have sufficient power, liquifying gases can be done.refrigerate it and keep it in liquid form.
Storage of cryogenic liquids is pretty good. We have dewars with such a low boil off rate that it takes months for the contents to warm up. Add in a system to recycle the boil off and it can be kept indefinitely liquid as long as you have power.
Yes but all that power and infrastructure has to be shipped to Mars. You have do it in a place where there is lots of ice, that means the poles, that means solar is useless, its pretty much useless anyway as a reliable energy source due to dust storms that can last weeks or even months but at the poles it really is useless. So lots of RTGs to ship there along with machinery to mine the ice, purify it, lots of power for the electrolysis to get your hydrogen and oxygen, refrigerate it and keep it as a liquid for use. Then lots more energy for the Sabatier process when you have the CO2 which is there and makes up most of the atmosphere but the atmosphere is only 0.095psi. The hurdles are HUGE, we are decades away from being able to make enough fuel to fill a Starship for the return journey. Elon makes it sound so easy, its anything but easy and the fact he says they'll do it with solar shows he is either lying or deluded. I think he's lying because he likes to sell dreams but they have to be taken with a lorry full of salt.
Another subscriber to the Common Sense Skeptic I see...![]()
And here I was thinking that the aliens would have it all built in preparation for our arrival. I guess we need relatively cheap rockets with a fast turn around to enable quick launches. Since it sounds like lots of trips will be necessary to get equipment there.Yes but all that power and infrastructure has to be shipped to Mars.
what stopping them from shippings lots of RTGs and the machinery they need for mining?So lots of RTGs
No seriously is this your word of the day or something?The hurdles are HUGE,
Getting the nuclear fuel required for RTG’s is not easy, cheap or quick, and will a substantial problem. I also feel getting water from the poles to the launch site will be a massive problem.And here I was thinking that the aliens would have it all built in preparation for our arrival. I guess we need relatively cheap rockets with a fast turn around to enable quick launches. Since it sounds like lots of trips will be necessary to get equipment there.
You’ve also written a lot of stuff unrelated to my post, I’m guessing you want my opinion or something, so let’s have a look.
Finally an actual huge (is this your word of the day or something?) problem. You could have skipped all the other preamble and just got to this.
We have pumps that work with low pressures but generally require incredibly clean fluid to function. Then there is collecting the volume required for creating enough fuel. Especially since it also has a high expansion ratio (600 to 1). Not sure how or if they can overcome it.
Also how do you quantify a huge problem vs a big problem or a large problem?
Or do you like you hyperbolic language because you want a certain pessimistic tone to your post?
Maybe there are impossible challenges that simply cannot be overcome with our current technology but you haven’t listed or detailed them in your post.
I never claimed it was easy cheap or quick to get fuel for RTG. Not sure where you got that idea from.Getting the nuclear fuel required for RTG’s is not easy, cheap or quick, and will a substantial problem. I also feel getting water from the poles to the launch site will be a massive problem.
The issues are immense. Huge, almost.
Re RTG's, IIRC they can be made easier/cheaper than the ones Nasa have, but there is a definite mass/reliability cost.
I seem to remember Russia made something like a couple of thousand of them, but they were used to do things like provide power to unmanned earth bound installations such as light houses, not survive launch into space, then the conditions of space and re-entry.
It's still not a particularly practical thing for something that is going to need a lot of power as the whole basis of the RTG is that it's a low output, longterm source, and you really don't want to be putting too much of that material on any one rocket.
Apparently the RTG from Appolo 13 re-entered the atmosphere and as far as NASA can tell the container survived intact and hasn't leaked any radiation.I can't imagine the FAA giving a licence for any rocket carrying multiple RTGs for the simple reason that if anything happened you could have a lot of plutonium raining down over the gulf of Mexico.
