19 May 2023 at 20:16 #41 NVP NVP Soldato Joined 6 Sep 2007 Posts 12,807 Dear God I think he's serious...
19 May 2023 at 20:45 #42 Thekwango Thekwango Soldato Joined 5 Feb 2009 Posts 17,223 Location N. Ireland All I can say to those that don’t believe it brings good luck, dont be such a bunch of neighsayers Also, clean it up and if it says Shergar on it your onto a winner!
21 May 2023 at 07:56 #43 bainbridge bainbridge Soldato OP Joined 9 Dec 2009 Posts 5,442 Location Bristol The horseshoe has been undergoing electrolysis since yesterday afternoon. @NVP I'll be holding you personally responsible for any reduction in luck as a result of using this method.
21 May 2023 at 07:58 #44 NVP NVP Soldato Joined 6 Sep 2007 Posts 12,807 If you notice a reduction then I've got a lucky pair of boxers you can have as compensation.
21 May 2023 at 12:20 #45 Mercenary Keyboard Warrior Mercenary Keyboard Warrior Soldato Joined 4 Aug 2007 Posts 22,442 Location Wilds of suffolk NVP said: If you notice a reduction then I've got a lucky pair of boxers you can have as compensation. Click to expand... I take it you never wash them to avoid washing the luck away
