If you're found with a banned breed, it's an unlimited fine and something like 6 months in prison
That's completely wrong,
If you're found with a banned breed, there's a whole load of stuff that goes on, it has to be inspected and checked - the court might even allow you to keep it and it be added to the list of exempt breeds, where you can continue to own it so long as it's muzzled at all times.
The people who get an unlimited fine or jail time, are at the absolute worst end of the problem, and are probably repeat offenders with a serious criminal history.
What Should You Do If You Suspect You Have a Prohibited Type of Dog
In the UK, owning a prohibited type of dog has legal ramifications. This post explains what you need to do if you suspect you own a banned dog.
Provided your dog is of good temperament and does not pose a danger to the public and provided you are someone the court would consider to be a fit and proper person to have a dog of that kind, you should be able to go through the legal process of obtaining a Certificate of Exemption which means your dog will be legal provided the conditions of exemption are complied with.For your dog to be exempted, it has to be:
- Neutered
- Microchipped
- Covered by third-party insurance
- Registered on the Index of Exempted Dogs
