Peerless assassin
Stop running stress testshi.. i have a thermalright phantom spirit 120 se and i use my cpu with msi b550m at kombo strike 3 but when im hit a stress test wit octt my cpu reach 90 celcius immediatly .... i cant solve the problem ...can you help me please?
The ps120se IS a dual tower cooler, 7 heatpipes and is better than the pa120...Stop running stress tests
Your cpu cooler will be ok for gaming and general pc stuff but a stress test will over power it in seconds.
You need a good dual tower or an AIO water cooler. But if you just game what temps do you see?
Read the message I replied to… and try again.The ps120se IS a dual tower cooler, 7 heatpipes and is better than the pa120...
I'd recommend checking it's fitted corrected and good paste applied
Today i will check it again... And i will share the results.... And how about arctic freezer ii 240 mm... Does it enough for 5800x3d?
hi.. i have a thermalright phantom spirit 120 se ....
Not sure what I missed? The ps120se is up there with/better than the rest of the air coolers on the market so you telling him to get a good dual tower cooler doesn't make sense. It will probably equal or better a 240mm aio as well which you've recommended whilst at the same time telling him to forget about stress testing..Read the message I replied to… and try again.
This one. I got mine 39.99 I think. Its a very good but pretty damn bigThe assassin is shooting up, it’s hard to find now for under £50.
When I got one I paid 29.99
Going to say it'll be fine for the 5800X3D especially if you apply -30 curve optimiser through PBO (or equivalent) which pretty much every chip should be capable of.Hi I am going to upgrade my CPU & GPU current have 3600 and looking to get a 5800X3D but not sure what cooler to go for would the Dark rock 4 be ok our would i need the Pro?
